Old May 15th, 2014, 06:57
Talyn's Avatar
Talyn Talyn is offline
Re: 2001 engine rebuild
I thought you were doing a rebuild?
Old May 15th, 2014, 08:32
slowjeep slowjeep is offline
Cylinder walls are in good shape so I won't be touching
that.
Old June 17th, 2014, 11:26
I'm back at it after a whole month. Now I can't tell which bolts are the correct ones for the oil pump. I found two that work, but the long one has a washer while the short doesn't
Old June 17th, 2014, 12:41
Talyn's Avatar
I don't recall the oil pump bolts having washers, but they might. I don't believe the oil pump bolts will fit any where else (especially engine internals) but there so you should have the right ones.
Old June 17th, 2014, 23:08
Here's what I have
Engine idle problems after engine rebuild (extremely high) SicNastyXJ OEM Tech Discussion 3 January 6th, 2012 17:46
Engine Rebuild Help! CUengineer OEM Tech Discussion 25 October 20th, 2010 16:03
Engine rebuild davinci Midwest Chapter 22 March 15th, 2008 10:50
Engine Rebuild jones95xj OEM Tech Discussion 5 February 15th, 2008 09:04
Engine rebuild Boz88xj OEM Tech Discussion 9 September 1st, 2003 00:20
