Old July 22nd, 2008, 20:37
4byfour 4byfour is offline
Elec fan vibrates jeep...
Hi, I've had my 2000 cherokee sport 4.0L 4x4 auto since monday(112k miles) and in the drive through lane at a local ffr (fast food restraunt) after 12 minutes of ideling in 96 degree heat the aux fan kicked on and scared me half to death...It shakes the hole jeep,hood vibrates, and is pretty loud. Obviously this is wrong. Is this a common symptom when the aux fan bearings go byby or is this a sysptom of a bigger problem like bad motor mounts or something???
Thanks for your replies !!
Old July 22nd, 2008, 20:53
AaronsJeep AaronsJeep is offline
Re: Elec fan vibrates jeep...
Hey, this could be a few things, some of the easier fixes. Make sure it's tight, meaning tightened down so you eliminate any wobble. And if you get any dried mud or a grease on the fan blades it will be unbalanced and start to wobble also, and you will feel it in the cab. Just my experience, I hope it helps?
Old July 22nd, 2008, 21:00
wolfpackjeeper's Avatar
wolfpackjeeper wolfpackjeeper is offline
i say replace the electric fan, its ether good or bad, and with your symptoms I would says its bad. Call it 100bucks on the outside for a new one, or you could probably get one cheaper if you look
Old July 22nd, 2008, 21:41
Mtb Jak's Avatar
Mtb Jak Mtb Jak is offline
mine is the same way, the blade is cracked.. yumm
Old July 22nd, 2008, 21:42
Mtb Jak's Avatar
withe the jeep off spin the fan and check for the crack.
Old July 23rd, 2008, 00:49
Timmy2XJS's Avatar
Timmy2XJS Timmy2XJS is offline
mine did the same thing. i took it out and cleaned it. i found there was a small rock jamed in a spot that was throwing the balance off.
months later it did it again but it was mud on it.
Old July 23rd, 2008, 07:57
XJumpmaster's Avatar
XJumpmaster XJumpmaster is offline
On mine, one of the mounting tabs was broken. It decided to jump into the mechanical fan before I could get it fixed. I was going 70 mph at the time. Scared the shiite out of me. Found an oem replacement on line for $130 shipped. Just make sure you get the 10 blade s-blade unit. That one is the most efficient oem replacement.
Old July 23rd, 2008, 10:42
mecompco's Avatar
mecompco mecompco is offline
We were riding in my buddies 2000 when the e-fan shed a blade--it was almost like DW--shaking the whole vehicle until the engine was turned off.
Old July 23rd, 2008, 12:03
Thank you all for the quick replies, I bought this for my son who will be turning 16 soon and I was afraid I had a LEMON...Will try all and report back what I find, THX again !!
Old July 27th, 2008, 11:33
cmose40 cmose40 is offline
Same situation here, just got an XJ this week, once in a while got a huge vibration, finally tracked it down to happen when the electric fan came on. found a crack in the fan, have ordered new one.
Old July 28th, 2008, 10:18
gradon's Avatar
gradon gradon is offline
One of mine(the original aux) had its bearings go a few days ago--It was so loud, I thought the belt was frayed or the p/s pump's bearings were the culprit.
Jeep Factory Service Paper Manual - Body Elec Diagnostic Procedures Thayer For Sale: Private Party Only. XJ ITEMS ONLY 3 May 12th, 2008 07:20
vibrates at road speed copper OEM Tech Discussion 2 March 30th, 2006 00:57
93 XJ AW-4 Vibrates in reverse newjeep OEM Tech Discussion 1 July 22nd, 2005 21:26
Elec Fan always on w/A/C Jeff-97XJ OEM Tech Discussion 9 April 12th, 2005 10:28
Streering Wheel Vibrates over rough road. Ideas? cem Modified Tech Discussion 11 December 12th, 2003 22:36
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
