231 Wide drive chain
Boatwrench
Petaluma, CA
While searching for information on how to check for a stretched chain I saw referenecs to a HD wide chain. I then searched a couple of on-line catalogs and found no references to a wide chain.
1. Is there a wide chain?
2. Other than being wider, waht's the difference? as in does it require changing drive sprockets?
3. Sources, preferably a NAXJA sponsor.
Thanks,
Tom
Tom,
The 231HD was used in Dodge Trucks (maybe other vehicles as well). As Kyung pointed out JB Conversions has a kit for around the $300 mark. You may be able to piece it together yourself if you can get a hold of a Dodge 231 case.
