If I read this correctly, the OP has an earlier 4.0L. What gen ???. 87-90 RENIX, 91-95 HO do not have dowel location pins. 96-up do have head dowel location pins. You can put on latter heads on block with out the dowel pins. You have to eye ball the location. If 96-99, then the dowel pins should be there.
