Old May 22nd, 2013, 16:51
ocean_jet's Avatar
ocean_jet ocean_jet is offline
Re: CB Radio mounting...
I went for a stock look and mounted it right under my radio. Changed 1.5 DIN stock radio to standard single size... and that gave me just enough room to mount the CB under it (with a little trimming of the trim panel).
The bracket was made from the exhaust heat shield.
Old May 22nd, 2013, 17:42
raneil's Avatar
raneil raneil is offline
That's pretty slick! Where do you hang your mike?
'98 XJ
'77 Stretched CJ5
Old May 22nd, 2013, 17:43
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
don't ask him that.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old May 22nd, 2013, 17:50
ocean_jet's Avatar
Originally Posted by rockclimber View Post
don't ask him that.
Haha... that threw me off for a second.
Thanks!
I had the little hanger that came with the CB mounted off to the left, kind of next to/behind the steering wheel... but didn't like that position.
Now I usually just wrap it around the shifter once and set it on the center console. It's in easier arms reach that way. I keep it in the center console storage box when I'm not using it.
Old June 28th, 2022, 20:25
faraiwe's Avatar
faraiwe faraiwe is offline
Installed a CB this past week. Selected a base Uniden model, small and inexpensive. Didn't want to drill and cut into trim, and wanted to be able to remove the radio and its wiring.
Tricky, but found out the connectors for the cig lighter/power outlet haven't changed, so the Wrangler JK adapter with a bridge/bypass connects perfectly, and leaves a pair of +/- wires with a fuse, to connect the radio.
Added a SAE connector to that, so I could unplug the radio. Makes it easy to connect to a standard cig lighter adapter with an SAE connector, too.
For bracket, and avoiding drilling, but keeping radio secure (instead of simply shoving it between seat and console), got a 3" wide zinc alloy ribbon with holes for bolts and retainers, etc. Construction materials aisle of any hardware store, single digit $. Cut to length, bent to shape, curved a lip and left a tab. The curved lip hooks to the bottom edge of the console trim, the tab on the end of the L-shape inserts between console and the shifter bezel. Not bad. Nothing more complex than a vise and an oscillating tool,
plus a rattle can.
Fairly happy about result.
Old June 29th, 2022, 07:49
RCP Phx RCP Phx is offline
Have fun talking to yourself, CB's are history as of the last century. Even FRS is almost out the door!
Old June 29th, 2022, 11:26
faraiwe's Avatar
There are places I wheel where there is no cell phone reception, but a CB will work.
Both my Jeeps now have them, and wheelin' buddies also got them.
I will certainly enjoy not being muted by lack of signal. =)
Ta.
Old June 29th, 2022, 12:36
xcm xcm is offline
I thought cb’s were dead too… but not around here! Every joe bob, Dylan and Cletus is on cb, and every little canyon has a specific channel posted at the entry.
You goto Easter jeep safari, where everyone has a $50k+ jeep, with everything on it, cb might be dead, sure!
Old June 29th, 2022, 14:18
jeep ride's Avatar
jeep ride jeep ride is offline
When I was still working we had the sprint push to talk radio's they worked fine around town start up the hollow and the radio just lost the signal turned itself off .
Old June 29th, 2022, 18:14
Anak's Avatar
Anak Anak is offline
Stranger
I have a ham license and a dual band rig. Still have to toss the CB in every now and then because that is what the rest of the group is running.
CBs are old and obsolete, but folks are still running them.
Old June 29th, 2022, 22:43
xcm xcm is offline
Kinda like jeep xj’s?
Old June 30th, 2022, 09:28
faraiwe's Avatar
I'm still waiting for that fine irony to hit a certain poster
Old July 4th, 2022, 06:27
89Mock 89Mock is offline
Go GMRS. more people use them because rugged radio got banned from selling unlicensed hams.
VHF radio mounting place Redxj5150 Tow Rigs and Trailers 33 April 12th, 2013 19:59
Mounting of Full size CB radio? Magus2727 Modified Tech Discussion 34 May 10th, 2010 19:14
[B]CB Radio Ceiling Mounting?[/B] mbiker72 Modified Tech Discussion 12 January 28th, 2008 17:10
Mounting an Amateur Radio kd5dwy OEM Tech Discussion 8 January 30th, 2007 12:17
Dual radio mounting azdesertrhino Modified Tech Discussion 17 January 8th, 2006 13:22
