Old May 22nd, 2020, 10:20
Unclewolverine Unclewolverine is online now
Wipers
is it typically the switch or the module when the intermittent wipers only work.....intermittently.
Old May 22nd, 2020, 20:44
lawsoncl lawsoncl is offline
Re: Wipers
Are they just not starting the cycle, or getting stuck in the up position and not returning at the end of the cycle. I've seen both the switch and the module fail and the wipers don't trigger. Not returning to the park position scan be the switch, module, or the contacts in the motor itself. I have repaired a module or two that had cracked solder joints.
Old May 22nd, 2020, 20:45
Re: Wipers
I assume it's the 1995 in your profile, btw.
Old May 23rd, 2020, 04:52
Re: Wipers
It is my 95, the wipers always work properly, just the delay function only delays the wipers when it feels like it. I figure its probably something in the module, if the solder is prone to cracking then that is most likely it because my mail route has some of the roughest, least maintained roads in the county!
yesterday wipers....today no wipers muddeprived OEM Tech Discussion 5 January 8th, 2010 22:05
TJ wipers woodironman OEM Tech Discussion 0 April 5th, 2008 19:11
Wipers randommuch2 OEM Tech Discussion 1 March 18th, 2008 03:29
no wipers!!help!!! XJ Beater OEM Tech Discussion 4 August 19th, 2006 07:54
Wipers sublime600 OEM Tech Discussion 3 August 18th, 2006 14:54
