Old May 20th, 2020, 14:15
TRCM's Avatar
TRCM TRCM is offline
Harbor Freight Jack Stand Recall
Wasn't sure where to put this.......
Check yours....
https://www.roadandtrack.com/car-cul...mwHdI7byxF1fbE
Old May 20th, 2020, 14:40
DustyWagoneer's Avatar
DustyWagoneer DustyWagoneer is offline
Re: Harbor Freight Jack Stand Recall
Thank you for the info.
I just went out to check ours and sure enough we own the very stands being recalled.
Old May 20th, 2020, 21:45
Greenspan's Avatar
Greenspan Greenspan is online now
I have the 56372 jack stands, but it only looks like the 56371 are recalled. I guess I'm safe? I don't know what the difference is, they look the same to me
Old May 21st, 2020, 07:10
89Mock 89Mock is offline
The difference is probably when they were made, and where the materials were sourced from.
I own the 6 ton model. I might find some time to take them in and swap them out. I've never had a problem with mine, but I guess it's when I DO have a problem I'll wish I'd have exchanged them.
Old May 21st, 2020, 07:37
two_door_rob two_door_rob is offline
From what I've seen, the teeth on the recalled ones were machined poorly and can slip. Saw a picture on FB comparing them to a non recalled set. Can't find it now, but if I see it again I'll post it up.
Old May 21st, 2020, 07:47
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Originally Posted by Nimrod View Post
A couple of years ago I bought some 12-ton jack stands from HF. The first time I used them they both collapsed as soon as I lowered the front axle of the Jeep onto them. I discovered that the pawls were cast steel, and VERY roughly cast. They just didn't have teeth to sufficiently engage the matching teeth on the riser. I took them back. About a year later I was hanging out at Avery's place when a HB 12-ton jack stand collapsed under Bricker's jeep, with Bricker sitting on the ground right next to it. Thankfully, no one was under it. BE WARNED -- I'VE PERSONALLY SEEN HARBOR FREIGHT 12-TON JACK STANDS FAIL TWICE. ITS A PIECE OF CRAP PRODUCT AND NOT WORTH THE RISK, in my opinion.
BTW, lest anyone think I just have some sort of axe to grind with HB, I have owed a set of their 6-ton stands for years and use them regularly.
Old May 21st, 2020, 08:46
Skwerly Skwerly is offline
Yikes. I've always said, if it has moving parts, go somewhere other than HF. Thanks for this.
Old May 21st, 2020, 08:53
It hit Hemmings, too. https://www.hemmings.com/stories/202...k-stand-recall
Old May 21st, 2020, 09:47
sdspearo's Avatar
sdspearo sdspearo is offline
Call me old school but I wouldn't own pawl type jack stands without a secondary cross pin. I bought these years ago for that reason and they haven't killed me yet....
https://www.amazon.com/Torin-Big-Ste..._t3_B000CO86BY
'96 XJ: Locked up D44's on 35" Milestar Patagonia's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Atlas 5.0, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old May 21st, 2020, 18:31
upsidedownxj's Avatar
upsidedownxj upsidedownxj is offline
Agreed. Honestly, unless you are buying some one time use (hand) tool that you are going to use only a handful of times at HF, you should definitely reconsider your priorities in life.
Old May 21st, 2020, 21:20
Greenspan's Avatar
I don't know man, back in the day harbor freight used to be cheap Chinese junk compared to everyone else. Now I feel like everyone else sells Chinese junk anyway so harbor freight isn't that different anymore.
Old May 22nd, 2020, 06:17
Anak's Avatar
Anak Anak is offline
Stranger
Sadly, too true.
And the only jackstand I have ever had trouble with was one of my Snap-ons. Go figure.
Baby it's cold outside.
Old May 22nd, 2020, 07:04
TRCM's Avatar
I got my 20" 12 spd drill press there on sale...and man, it has been awesome.
Only thing I have had to do other than use it is replace the on-off switch, as it stuck in the on position and I got tired of unplugging it when I was done.
It was on sale for like 249 back then (over 12 yrs ago) and was recommended by someone who told me when it bound up while using a hole saw for some cage tubing, it didn't stop, it swung the 6' piece of tubing around and knocked a hole in the wall and 'bout took his head off as it swung.
It has not disappointed me yet..........but it could use a better quality chuck....which is an easy fix.
I also got my newer tool chest and hang on cabinet from there......very impressed with them.
I did have to shim 1 wheel tho so it sat perfectly level empty, and I fully expect the zerk fittings in the aluminum wheels to be an issue.
I do agree tho, most things there are single use................
Old May 22nd, 2020, 16:56
Pretty darn true actually.
I work in the trades and it is hard to find domestically made stuff these days. Even companies like klein are importing a large portion of their tools.
Old May 23rd, 2020, 16:44
madmax's Avatar
madmax madmax is online now
I have three sets 15year old 7ton stands from HF. Has HF quality gone down hill?
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Greenspan
Harbor Freight HD Jack Stands? SeeingSpots Colorado Chapter 9 June 21st, 2013 12:06
Harbor Freight Trans Jack Iwannagofishin OEM Tech Discussion 9 April 14th, 2012 23:35
Harbor Freight Hi Lift Jack mbogosia SEC For Sale / Wanted Forum 5 April 17th, 2009 18:18
Need a floor jack - Harbor Freight? Is this one alright? fdsa487 SoCal Chapter 18 May 14th, 2007 11:38
harbor freight jack stands DansGreyMj Tools and Garages 4 August 19th, 2006 05:46
