Old April 9th, 2019, 17:52
Tacowhip's Avatar
Tacowhip Tacowhip is offline
Intermittent 21 code.
Hey guys. Iím getting an intermittent 21 code, Oxygen sensor. Itís been throwing this code ever since Iíve bought the Jeep 3 years ago. I replaced it with an NTK. Still throwing the code. Any body have any information on this issue, or a wiring diagram, possible fuses? Thereís also a 12 code thatís always there. Rarely do I disconnect the battery. Itís a 95 sport 4.0. Thanks.
Old April 9th, 2019, 18:21
lawsoncl lawsoncl is offline
Re: Intermittent 21 code.
Have a good look at the wiring and make sure it's not hitting the exhaust and shorting out. If it's not secured well, it can melt against the exhaust manifold.
Old April 9th, 2019, 18:56
Tacowhip's Avatar
The wiring is zip tied away from the exhaust and not rubbing anything. All good there
Old April 11th, 2019, 18:39
Dragonslayer Dragonslayer is offline
Check the O2 harness where it exits the end of the square plastic wire harness tube that is near to exhaust tube #1. Often a previous mechanic will route the O2 sensor wire too
near to the exhaust tube and fry the wires, and then perform a dodgy repair. Open up
the black plastic corrugated split cover (wire harness) starting at this point and follow it
down to the sensor. Inspect for anything that looks stupid, or out of the ordinarily.
This happened on my car. After months of fiddling around, and 3 new O2 sensor$, I checked
the wires there and found a wire harness repair done by a previous owner using Romex
home wires and non-insulated crimped connectors! All was good after correcting this with
proper wires, and twisted & soldered splices, and double layers of heat shrink tubing.
P0340 Code - Replaced CPS, code persists acruz95 OEM Tech Discussion 1 January 24th, 2019 12:44
Code 27 Intermittent hesitations, power loss, stall johanwayne OEM Tech Discussion 2 October 24th, 2017 17:26
Non intermittent intermittent wiper.... techno1154 South East Chapter 2 July 5th, 2017 07:19
1990 rear wiper motor not intermittent, I want intermittent! xjtrailrider OEM Tech Discussion 12 January 23rd, 2014 21:54
95 Intermittent start up. No check engine light in "on". Code 12? HELP!!? tg22ar OEM Tech Discussion 30 May 13th, 2013 21:33
