Old March 29th, 2019, 20:48
SouthSeaPirate's Avatar
SouthSeaPirate SouthSeaPirate is offline
Exclamation 4.0 getting really noisy! Have I killed another one? Videos
Few months ago I put in a 130k mile 98 ZJ engine in my XJ.
New timing chain, sprockets, and gaskets.
No slack in the rods from what I could tell when I had the pan off.
All has been fine for a few thousand miles.
Over the last week it has been slowly getting noisier and noisier.
At first was so little that I was even questioning myself if I really heard anything out of the ordinary. Now, it's crazy noisy.
It otherwise runs just fine. Doesnt seem down on power or anything.
Please try to ignore the fan running in the first video. It was nowhere near as loud as the engine noise.
Second video is showing the lag in building oil pressure. I should have waited as after it sits, it takes much longer to build pressure, but gives you an idea that it is not normal operation.
https://www.youtube.com/watch?v=-3Vg...ature=youtu.be
https://www.youtube.com/watch?v=fq9n...ature=youtu.be
What could this noise be? Main or crank bearings?
Old March 29th, 2019, 21:07
cinema cinema is offline
Re: 4.0 getting really noisy! Have I killed another one? Videos
i'm sure this is not it because you are skilled enough to install a new timing chain. however, the video sounds like a giant open vacuum. you've hooked up a vacuum gauge already right
Old March 29th, 2019, 22:13
Hypoid's Avatar
Hypoid Hypoid is offline
What brand oil filter?
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 30th, 2019, 06:48
You hear the fan. No vac leak.
Think like marbles in a tin can.
4 day old STP.
Before that was Wix.
Old March 30th, 2019, 10:07
devildog0's Avatar
devildog0 devildog0 is offline
With the delayed pressure build up im thinking you may have got a filter with a bad antidrain back valve.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old March 30th, 2019, 19:12
Same result before and after new filter.
Old March 30th, 2019, 19:14
Noise issue has been solved with the exception of the noise a tractor engine normally makes.
It was the water pump. First time I took off belt it seemed fine from what I could tell.
It was still a tad noisy from the first tho; reason I took the belt off the first time.
So now to figure out the oil pressure issue.
Old April 8th, 2019, 19:20
denverd1's Avatar
denverd1 denverd1 is offline
You put in new oil pump when you had the pan off?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
I killed another spikeypuck NorthWest Chapter 26 October 2nd, 2010 13:04
My 2 1/2 yr old nephew was killed Lady XJ SoCal Chapter 38 June 16th, 2008 05:27
I KILLED MY '94! Ryno Non-Tech / Off Topic 0 April 16th, 2007 10:45
Think i killed my cat Switch1625 OEM Tech Discussion 17 April 30th, 2006 11:08
