Old July 12th, 2017, 08:44
Jimmothyb Jimmothyb is offline
Turn signals not working
I have a 1990 jeep cherokee 4.0L manual and 2 days ago my turn signals stoped working. My hazards work just fine so it's not any of the bulbs and since then I've replaced the fuse, flasher relay and the turn signal switch and still no luck and the old fuse was blown and there was light corrosion on the contacts. The turn signal switch looked in good condition.
Old July 12th, 2017, 08:52
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
I would check the fuse is getting power.
Could just be poor contact with the fuse.
I had trouble with turn signal relay when I put led bulbs in the tail lights. After I bought a new relay that didn't mind the led bulbs the turn signals worked fine.
I believe the renix c101 plug that could cause so many problems was eliminated by 1990.
If brake lights and turn signal were out then it could be a power line that attached at the batter terminal. Some times they corrode.
Old July 13th, 2017, 13:32
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Turn signals not working
Probably, since the old fuse blew, and the new fuse did not blow, then some where the power wire shorted to ground and melted the wire, so it is now an open circuit. Is the new fuse getting power. Is power getting to the other side of the new fuse? Is power getting to turn signal switch.
Time to follow the power wire to the point where the power dies.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 10th, 2019, 12:04
trooper06977 trooper06977 is offline
I have a 69 cherokee I had bad brake light switch replaced it replaces turn signal switch in columb all bulbs and multi flasher cube and still have no turn sognals or 4 way flashers
Old April 7th, 2019, 12:24
crofoot crofoot is offline
I fought this problem for a while till i found that there are two flashers,one for 4 way and one for turn signals.I know it's simple but be sure you have changed the correct one.
Old April 15th, 2019, 19:06
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Make sure the terminals in the fuse box are good. The clutch master likes to leak into the fuse box and cause corrosion. The terminals will crack and appear to make contact. While in reality they are open circuit.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Turn signals not working flingshot OEM Tech Discussion 1 June 22nd, 2016 19:53
99 with non-working turn signals Ben824 OEM Tech Discussion 6 November 4th, 2012 20:38
Turn signals only working for 1-5 flashes NYPDJeep OEM Tech Discussion 8 November 23rd, 2007 11:32
Turn signals not working quite right...help?! CoastieJ OEM Tech Discussion 4 June 29th, 2007 23:27
All 4 turn signals stopped working Maz OEM Tech Discussion 14 June 18th, 2005 09:26
