Old August 14th, 2003, 06:42
Speed_racer's Avatar
Speed_racer Speed_racer is offline
Unhappy Gas Gauge Gone Mad!!
Well, my gas gauge has gone fritz, When i get on the gas hard, the gas gauge drops constantly, like, from F to the Low Fuel light turning on... Then when i Get back to normal accel, or I stop, the gauge goes back to an extremely accuracte reading...
Whats the fix?!?
Old August 14th, 2003, 06:50
Lawn Cher''s Avatar
Lawn Cher' Lawn Cher' is offline
Maybe its actually measuring fuel flow! J/K
Check the wiring harness going to the fuel sender, maybe a loose connection?
Old August 14th, 2003, 11:40
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
You do realixe, I hope, that the tank sender is a float on a lever arm at the front of the tank. When you get on the gas "hard," the fuel in the tank is forced to the rear of the tank due to inertia. The level of fuel at the sender then drops, and the gauge responds accordingly. You'll see the same phenomenon if you watch the gauge when ascending a long, steep hill.
Perhaps the solution is to not get on the skinny pedal so hard ... but then I looked at your screen name and said "Nah!"
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old August 15th, 2003, 12:40
LT1XJ's Avatar
LT1XJ LT1XJ is offline
Over the years the sender wears and it fluctuates a lot more than stock. Sometimes the float gets bent or bends causing some of the problem. Or it could be your gauge, but I would bet on the sender.
Old August 16th, 2003, 05:37
GoalPoster GoalPoster is offline
Where do I find this 'sending unit' . . . my gas guage is as reliable as my annual raise
Old August 16th, 2003, 08:56
Jump This's Avatar
Jump This Jump This is offline
Just another minion!
Inside your gas tank.....
Gas Tank Skid lobsterdmb Wanted: Private Party Only 1 December 7th, 2003 21:05
gas gauge MonsterXJ OEM Tech Discussion 3 September 8th, 2003 10:07
Gas gauge juicexj24 OEM Tech Discussion 9 June 30th, 2003 11:18
Gauge Cluster Swap w. Column Shift A/T comanche91 Modified Tech Discussion 10 May 1st, 2003 18:08
Gas Gauge one 1999 XJ Manuel OEM Tech Discussion 4 April 15th, 2003 16:15
