Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old September 29th, 2010, 11:45
XJRunner's Avatar
XJRunner XJRunner is offline
sound deadening and insultaion.
I'm lookin for cheap insulation. I found this stuff and heard some reviews from people saying it worked pretty good
http://www.homedepot.com/Quick-Roof/...atalogId=10053
I also found this. It looks almost like dynomat. What do you guys think?
http://www.homedepot.com/Building-Ma...atalogId=10053
Old September 29th, 2010, 12:18
Mesh's Avatar
Mesh Mesh is offline
NAXJA Forum Supporter
Re: sound deadening and insultaion.
It's better to use the real thing. It might end up having a strong asphalt smell or the performance will not be as great. I have RAAMmat BTX on my floor it's $89.96 for 62.5 square feet.
http://www.raamaudio.com/index.php?p... mart&Itemid=3
89 Limited, 4.7L 10.6:1 CR, Full 2.5" SS Exahust, OME 4" 265/75R16
Old September 29th, 2010, 13:02
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Not sure about the second, but the first is just butyl rubber with a foil covering. I patched up a metal roof with that stuff. No obnoxious odor or anything, but it's no cheaper than the stuff Mesh used, and probably more difficult to apply (6" wide vs 15").
Old September 29th, 2010, 14:21
kcjeep6 kcjeep6 is offline
Nothing from Homedepot belongs on a Jeep!
Old September 29th, 2010, 14:38
hubs97xj's Avatar
Loctite? Hardware? Paint? Bungee cords? Ball mounts? Hitch baskets? Coolers? The nifty foam rubber matting people stick in the cargo area? MDF for speaker enclosures? Indoor/outdoor carpet?
Old September 29th, 2010, 17:02
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Nope, all crap
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old September 29th, 2010, 17:08
hubs97xj's Avatar
Dang, and I was just heading out the door for another roll of that stuff. I suck at this game.
Old September 29th, 2010, 20:03
Q&A
Q Loctite? A Work
Q Hardware? A Work
Q Paint? A Summit
Q Bungee cords? A Never use them
Q Ball mounts? A Scrap pile/ Work
Q Hitch baskets? A That should not be on a Jeep
Q Coolers? A http://www.bear-aware.com/ordering_information.htm
Q The nifty foam rubber matting people stick in the cargo area? Non stock JW
Q MDF for speaker enclosures? A Too much work
Q carpet Indoor/outdoor? A Well may be!
Old September 29th, 2010, 20:08
Gonepostal Gonepostal is offline
This stuff looks pretty good.
http://www.lizardskin.com/
Old September 29th, 2010, 21:24
Mesh's Avatar
I want to try some Lizardskin as undercoating. The price per gallon is scary. Then you look at how many gallons they recommend to use and it gets worse. Still it's not Dynamat what are they selling it for these days $100 a square foot.
Old September 29th, 2010, 23:44
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
I used a product called Noise Killer, comes in a spray or a gallon container. it can be hard to find but it works extremely well, and is about $25 a can.
Old September 30th, 2010, 00:00
XJRunner's Avatar
link?
Old October 1st, 2010, 10:46
RadioShackSpecial's Avatar
RadioShackSpecial RadioShackSpecial is offline
http://www.noisekiller.co.uk/
Thats what google found.
Might want to check Summit as well, they have quite a few options in regards to noise/heat insulation.
Old October 3rd, 2010, 08:33
xj_chef xj_chef is offline
just purchased RAAMMAT BXT II for my '93 xj.
i have no sound deadening at all on the floor.
pulled it all out to fix water leak and patch floors up.
Old October 3rd, 2010, 08:44
XJRunner's Avatar
im going for cheap as my jeep will eventually be a race jeep
Rate This Thread:
Sound AND heat deadening Matt S. Modified Tech Discussion 22 April 7th, 2007 15:05
Sound Deadening Locations shaddady34 OEM Tech Discussion 0 January 17th, 2007 04:25
Sound deadening material: barrier/composite lilredwagn For Sale: Private Party Only. XJ ITEMS ONLY 1 September 22nd, 2006 05:45
Sound deadening RichP Modified Tech Discussion 20 June 15th, 2006 21:47
any cheap tricks for sound deadening? db_ghost Modified Tech Discussion 13 December 28th, 2003 20:34
