Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old January 25th, 2021, 14:00
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Rusty Roof
My roof is pocked with rust spots. Looking to clean it up and use RaptorLiner or such on it. ZERO experience in this area.
Figure DA the whole roof, apply epoxy primer or such then either paint or RL.
Help me out.. don't need fancy.
I'm a 'Do-it-Twice' kinda guy.. or..
Cross thread's better than 2 lock-washers
1999 XJ Sport 4.0L Black
Old March 5th, 2021, 08:46
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
FWIW:
Wire wheeled the rusty spots and entire roof.
Sanded with 320 grit.
Sprayed with Eastwood Platinum Rust Encasulator
https://www.eastwood.com/eastwood-ru...-platinum.html
and will follow up today with Eastwood High Gloss Chassis Black.
Rust wasn't terrible but this should control it.
Thanks for all the advice
Old March 5th, 2021, 19:42
Skruffy's Avatar
Skruffy Skruffy is offline
Rusty Roof
I had the same problem. Wire brushed it, cleaned it super clean, primer, then rolled on two coats of a truck bed liner. No more rust. Been about five years and still holding strong.
Old March 8th, 2021, 08:58
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
Thanks Skruffy: "I had the same problem. Wire brushed it, cleaned it super clean, primer, then rolled on two coats of a truck bed liner. No more rust. Been about five years and still holding strong."
Yup, didn't like the way it turned out with encapsaltor + rattle can. Gonna re-scuff with 220 or even 150 grit then self-etching primer and roll on black RaptorLiner. If I'm gonna have orange peel it might as well be intentional. See signature..lol.
Old March 8th, 2021, 09:27
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
I'm a bit concerned about the liner possibly peeling back from the edges at the rain gutter. Did you do anything to address/prevent this? I'm thinking a bead of silicone or roofing junk.
Old March 8th, 2021, 14:20
Skruffy's Avatar
Rusty Roof
I just put some tape down first and removed it while the liner was still wet.
Old March 8th, 2021, 16:22
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
Thinking more of 'sealing' the edges after it dries or maybe just before.
Nearly done. Scuffed with 150 and hit with a couple coats of self-etching primer. Gonna let it set up overnight, heat the shop in the morning and roll a couple coats of the Raptor. XJ is black so black Raptor.
Old March 8th, 2021, 20:01
UtahXJ98 UtahXJ98 is offline
Re: Rusty Roof
I just did this at the corners of the front windshield. I lucked out it was just surface mostly. I wire wheeled it then put rust killer primer on it, body putty, primer again, touch up paint.
Old March 8th, 2021, 20:11
JonnyCat63 JonnyCat63 is offline
Re: Rusty Roof
I did the Raptor Liner on 2 XJ's, one F250, and the inside tub of a CJ. Turned out well, will do it again when the time comes.
Here's a thread about Raptor on my 99
https://www.naxja.org/forum/showthread.php?t=1159582
Old March 9th, 2021, 07:27
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
Is the windshield rubber easy to R/R? Shouldn't need new if I can keep the old intact.
Nice job.
Old March 9th, 2021, 08:06
Re: Rusty Roof
Nice job.
You can't R&R the windshield rubber. It wraps around the windshield and gets installed as part of the windshield change. I just pulled the old one off to do the Raptor Liner because I knew I was going to change the windshield. If you pull it off, you'll never get it back on properly. IIRC, I even needed to cut some of it out.
Now I have read where some people say the rubber is just for looks and doesn't actually seal anything up. That's probably true, I saw how they installed the windshield, and it's basically just sealed in with goop, or whatever they use. Some people have posted that they were able to remove just the rubber and then just glue it back in and not change the windshield. I wouldn't do it that way, but UMMV.
Old March 9th, 2021, 08:11
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
Thanks, I'll continue working around it. Paint appears good underneath so should be good.
May as well ask: IIRC? UMMV? Acronym I can spell, deciphering them is another story.. lol
Old March 9th, 2021, 08:51
Re: Rusty Roof
Sorry.
IIRC. If I recall correctly.
UMMV. Your mileage may vary.
I thought I was the only one who had trouble deciphering acronyms. Maybe I'm hipper than I thought!
Old March 10th, 2021, 09:03
NOTNSUV's Avatar
You Guys ROCK!
Re: Rusty Roof
Got 'er done. Rollers that come with Raptor Liner are junk. They stick and won't roll, disintegrate and cause lumps in the compound. Fortunately, I picked up a couple 1/4" nap from Home Depot and finished up with them, then took a wide gasket scraper to it after it had cured overnight and slid it over the whole roof removing high spots, aka: chunks of roller, without scarring the finish. It looks pretty good, but with the rest of the XJ muddy, it sticks out as the only shiny spot on the whole rig. Appearance was not the goal, sealing from rust was, so that's a success. As soon as it gets dirty and bakes in the sun awhile it should look fine. Or, if I wash the rest of the jeep maybe... lol.
Resisting an aftermarket roof rack and will probably put the OEM rack back on. This one is up for consideration:
https://www.amazon.com/dp/B07K5618YC...v_ov_lig_dp_it
and I really like the aluminum rack from JCR but $800 + any mounting brackets is, well, you know.
https://www.jcroffroad.com/product/XJRK.html
Old April 15th, 2021, 05:39
Irishdeath Irishdeath is offline
Re: Rusty Roof
Where did you buy your raptor roll on kit? I’m going to the bottom of my doors as they need some help. Did one lot do the whole roof?
Roof hole leak, roof racks Ecomike OEM Tech Discussion 4 April 10th, 2017 20:11
building a roof mount light bar... how high off the roof should the mounting face be? ericfx1984 Modified Tech Discussion 2 June 16th, 2011 20:25
Roof Wind Resistance Comparison: Roof Rack vs. Spare vs ... Skibum12189 Modified Tech Discussion 4 February 8th, 2010 18:00
Roof Rack Weight and Roof Load Capacity xj_mike Modified Tech Discussion 3 December 29th, 2007 15:26
mounting lights on the roof w/o roof rack ucilxj Modified Tech Discussion 7 November 9th, 2004 19:55
