Old June 9th, 2021, 14:04
asymptonic asymptonic is offline
Recommended 8.25 Axle
May be having issues with my current axle (or may not) but want to preorder a replacement that may become a spare. What do people recommend in an 8.25 rear axle? 1998 and I'm the original owner, so almost certainly a 29 spline. 3.07 gear ratio if that matters.
1998 4.0 I6, AX15, NP231
Old June 9th, 2021, 17:30
Unclewolverine Unclewolverine is offline
Re: Recommended 8.25 Axle
I have an extra 01 3.55 open if you happen to be driving through kansas in the near future.
Old June 9th, 2021, 21:26
RCP Phx RCP Phx is offline
Yukon hands down!
Old June 10th, 2021, 04:29
75SV1 75SV1 is offline
Depends on what your rig status is, ie tire size. Also, what type of driving. IE Highway around town, wheeling???
I'd be temped with a manual to get a 97+ with the 3.55 gears. Then plan 31" tires.
Old June 10th, 2021, 06:01
Anak's Avatar
Anak Anak is offline
Stranger
Put me down as another for using this as an opportunity to get better gears.
I am running the AX-15 with 4.10 gears and 30" tires. I DD it as well as do trips that are 1,000 miles of freeway, a few days off-road and then another 1,000 miles of freeway back home. The gear/tire combination works well for me.
Old June 11th, 2021, 05:47
Nothing special. AX-15 with stock sized tires. I don't do any crawling, just offroading on 4x4 roads in Big Bend. I went with the Yukons. Not too expensive and shipped fast.
Old June 11th, 2021, 07:13
I still might look at getting a stock axle with 3.55 gears. I remember some hills in Austin. Also, should be good for 31" tires.
I have a '88 Comanche with a manual trans. Drove great. I've been trying to 'upgrade' it for a long time. I was on stock tires 225 ratio. I remember getting 23 mpg. A neighbor's kid bough a Comanche. He broke his axle. So, I gave him mine. He said it performed much better. I wonder if someone swapped in a 3.55 from an auto at some point.
Old June 11th, 2021, 07:57
lawsoncl lawsoncl is offline
My 89 MJ originally got 23 mpg with with 3.07 axles, stick and stock tires. 5th gear was unusable on hills and the passes. Then I lifted, swapped in 4.10/.411 axles and 32" tires. Eventually swapped in an AW4. Still gets 17-18 now.
Old June 11th, 2021, 10:26
Sort of had similar results. Just different vehicles. One of my 98 XJ, I lifted to 4.5". I had the 3.55 gears. A bit sluggish. Then on to 4.10 gears. Drove good. I might have had issues with hills in WV. I did bore out the TB to 60mm. Really helped. Then I went to 32's. Still OK, a bit of other problems. This is with an Auto trans. I am getting about 16-17 mpg on it.
I think the OP, could get a 3.55 axle fairly cheap out of an auto XJ. 31's might fit OK on a stock, or even do a Budget Boost. Then maybe add a Lunch Box locker. So, nothing big $$.
I'll have to see what my mpg is on my newest 'Rig'. 2" lift, 3.73 gear and narrow 31's. Auto trans. I did get 20-21 on my stock 98 once in a while.
10w40 recommended summer / 10w30 recommended winter by engine rebuilder? Jonner OEM Tech Discussion 24 September 20th, 2014 13:57
Recommended fab shops EnderUSAF Arizona Chapter 8 October 30th, 2011 09:15
recommended tires? TLowery04 ColoradoFest 2007 2 June 26th, 2007 19:15
Recommended Winch SwiftShot Non-Tech / Off Topic 8 April 10th, 2007 16:00
Recommended shop Grizzley North Atlantic Chapter 11 November 17th, 2004 22:16
