Old November 3rd, 2007, 20:51
mustangconv85's Avatar
mustangconv85 mustangconv85 is offline
Axle help needed
I'm buying all the parts needed to install 4.88 gears in my 88 Cherokee its a stock Dana 30 and stock xj Dana 44 i need to know if these are the right carriers
Dana 30 carrier - http://www.drivetrainspecialists.com...oduct-305.html
dana 44 carrier - http://www.drivetrainspecialists.com...oduct-521.html
Thanks in advance (I'm not installing the gears i have someone that knows what their doing thats going to install them for me i just have to have all the parts waiting.)
Old November 4th, 2007, 01:21
Rawbrown's Avatar
Rawbrown Rawbrown is offline
Re: Axle help needed
No, don't waste your money on loaded carriers. Bare cases usually run around $60 each and all the internals will swap right over. If you can afford it, now is the time to go with lockers. Detroits will replace the carrier so you shouldn't need to buy them.
FYI,
you need...
front and rear gearsets
front and rear master install kits
front and rear bare carriers for 3.73 and higher front and 3.92 and higher rear.
thats 6 items. should run you around $550 or something for all your parts.
Old November 4th, 2007, 01:57
well i'm just trying to get the gears installed cause i won't be able to afford lockers for awhile i plan on putting a aussie locker in the rear and a ox in the front but the front will have to wait about another year. I can get empty carriers for 125 shiped so i can swap out the spider gears from my front but i don't think i can with the 44 cause its limited slip
And i already have the gears and install kits http://www.jeepinoutfitters.com/scri...?idproduct=998
Old November 4th, 2007, 01:03
Rawbrown's Avatar
then whats better on the rear 44 is not to get a new carrier but rather get a thick gearset. it allows you to run the 3.73/down carrier break with 3.92/up gears. Thick gearsets should only cost maybe $20 more. Its a much cheaper option on the 44.
that front bare case for the D30 shouldn't run you more that maybe $60 plus shipping from a good vendor.
Old November 4th, 2007, 01:07
but i already have the gears so just to get it going for now should i get the carrier for the 44 that i posted and get a bare carrier for the 30 and just swap out my spider gears to the new one
Old November 4th, 2007, 11:42
ttt anybody know if these are the right carriers if there links don't work anymore here are the part numbers 706004 and 25806x and here is the website http://www.drivetrainspecialists.com/index.html thanks
Old November 4th, 2007, 13:08
Rawbrown's Avatar
they are both loaded carriers and that is wasted money.
http://www.drivetrainspecialists.com...oduct-308.html
you want bare so that you can swap parts.
at the $$$ you would spend on the loaded carriers you can pick up bare carriers and a lockright almost.
Old November 4th, 2007, 13:27
ok so i'll get a loaded carrier for the dana 44 and the bare carrier for the dana 30 i know i'd almost have enough to get the locker but i won't have enough to get it in time and i need to get these gears in so a little extra money in the long run don't bother me just as long as i can get it moving now
Old November 4th, 2007, 13:31
Rawbrown's Avatar
open carrier front and rear...
http://www.drivetrainspecialists.com...oduct-546.html
Old November 4th, 2007, 13:36
ok empty carriers it is and i'll just try to borrow some more money off of someone to get the aussie locker thanks for the help
Axle info needed!!!!!! crusTodd Modified Tech Discussion 8 June 26th, 2007 08:08
Front Axle help needed!!! jimboleblanc South East Chapter 10 May 8th, 2007 13:12
NEEDED ASAP: d35 c-clip axle xcm SoCal Chapter 25 April 9th, 2007 10:25
Axle Setup Needed andersonsys NorthWest Chapter 2 August 11th, 2006 23:18
Axle pick-up help needed - Burbank to Sac basalt51 Sierra Chapter 1 February 6th, 2004 15:39
