Will TJ front axle shafts fit into an XJ axle ?
DaveB
My 86/92 XJ's tired front dana 30 axle needs to be rebuilt. I have a 99 TJ front dana 30 axle from a wrecked parts jeep that I bought. The axle housing was damaged in the wreck but the internals all look good. So does anyone know if I can take the axle shafts, brake parts and knuckles off the 99 axle and put them onto an 86 axle ?
Dave
86/92 mixed up XJ (sheet metal and axles are 86, rest is 92)
84 cj8
85 K30
yep. you have two choices here:
swap ONLY the axleshafts
or
swap EVERYTHING except the housing and gearset
any other combination will not work well :rolleyes:
if you have a HP 30 itll be sweet with those 297x u joints
Thanks
Thanks, that is just what I needed to know. I was hoping that I could do it since the TJ axle only has 19K miles on it. Now if I could find someone who needs the 3.73 gears and antilock brake stuff from the axle.
Dave
