Old November 29th, 2008, 17:32
YELLAHEEP's Avatar
YELLAHEEP YELLAHEEP is offline
'89 Comanche - front parking lights/dash lights not working
Did some searching but nothing really seems to match my issue.
Dash lights: When I pull the head light switch, no dash lights. When I turn the switch (rheostat) to dim/brighten the dash lights, nothing. When I turn it the other way to turn on the dome light, I get dash lights.
Bad headlight switch?
Parking lights: Tail light operation is fine. When I pull the headlight switch, the right and left turn signal green arrows light up. Signals and hazards work fine with the headlights on, front ambers light up for the turn signal, but I think its the parking filament lighting up and not the brighter turn signal filament. Amber corner lights work fine but don't blink with the turn signal. (I believe they should alternate on/off with each other?)
Fuses are fine, just replaced the bulbs, the contacts in the sockets are in great shape with good electric lube.
Ideas?
Old November 29th, 2008, 17:38
Downthemachine Downthemachine is offline
Re: '89 Comanche - front parking lights/dash lights not working
Seems like two issues, a bad switch, and possibly bad grounds
Old November 29th, 2008, 17:49
definately check your grounds and get a switch. I've had a few cars do exactly what you said with, turning the dimmer to dome the dash lights turn on. Check your tail light grounds, and make sure they're not corroded.
Old November 30th, 2008, 20:01
YELLAHEEP's Avatar
Tail lights work fine in all modes.
Grounds up front must be ok - all circuits share the same ground wire path. Test light shows no power going to the turn signal circuit to light up the bright filaments in the turn signal bulbs.
It's just interesting that the green arrows light up just like a burned out bulb in the circuit would.
I think I'll remove the bulbs and see if the green arrows still light up - that should indicate a short further up the harness I'd imagine.
Then I'll probably look at the connector between the harnesses and check for power to both sides and go back thru the main harness and connectors from there.
Old November 30th, 2008, 21:33
ehall's Avatar
ehall ehall is offline
dash should not come on with interior lights, they are separate circuits and fuses
bad switch explains all of your problems
my '91 beater rebuild
Old December 4th, 2008, 15:56
matttaylor1976 matttaylor1976 is offline
another quick check for the front marker lights is to pull the lens and giggle or push the connectors from the back of the sockets. Mine were doing the same thing and it turned out that the internal connectors in the socket had completely corroded away. I had to rewire the sockets to restore the lights.
No front parking lights tkjeeper Modified Tech Discussion 14 September 29th, 2008 16:18
Parking and Dash Lights..... fatty OEM Tech Discussion 1 May 1st, 2008 11:33
Interior and dash lights, parking brake release joshv98xj OEM Tech Discussion 2 January 5th, 2007 16:55
Interior/parking lights not working... JeffsJeep04 OEM Tech Discussion 12 February 22nd, 2006 11:20
tail light and dash lights not working 87xjeep OEM Tech Discussion 3 June 23rd, 2005 22:07
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
