OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
0331 to 0630 head conversion question
Ok so my 0331 head cracked Cherokee and I replaced it with a 0630 head.
its seems after reading all the forums and engine specs the two things that are different are the spark plug coil strip and the exhaust ports. So does anyone make the brackets to hold up the coil strip? Or can someone link some pictures. And is there really a difference in the exhaust ports that I need to worry about. I gone through a lot of info and some say no change is needed and some say the exhaust ports need some sort of bracket. And if it does need a bracket does anyone make one? Thanks |
#2
Re: 0331 to 0630 head conversion question
https://www.naxja.org/forum/showthread.php?t=937214 Quote:
Yes, exhaust ports are different. You will need a manifold and gasket from 97-98 to bolt up to your 0630 head. I had a shop to tie all the exhaust together. Its just not that easy to find drop-in replacements that bolt up to so many different parts. . . manifold, cat, downpipe, etc (especially if you have the 4 O2 sensor california setup, i did not) Here are my notes from replacement. 5000 miles later, and so far, so good. https://www.naxja.org/forum/showthread.php?t=935856 hth, ixj |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
0331 to 0630 Swap Kit | wilsmick | For Sale: Private Party Only. XJ ITEMS ONLY | 13 | September 11th, 2014 17:12 |
0331 head swap question | GrimmJeeper | Modified Tech Discussion | 27 | September 8th, 2008 20:56 |
valve carbon or 0331 head issue? 0630 swap? | wilsmick | OEM Tech Discussion | 12 | May 22nd, 2007 20:13 |
0630 vs 0331 | Root Moose | OEM Tech Discussion | 26 | October 5th, 2006 19:56 |
