Old December 29th, 2006, 16:13
98stocker 98stocker is offline
Fix for weak tailgate struts...
I wanted to throw out a semi fix for those with weak struts or added tailgate weight. After adding a nice set of 6x9 inch speakers to the rear hatch on my 98, the struts could not quite keep the hatch up. I found that the mounting area on the hatch for the top of the struts is large enough that you can move the bracket for the top of the strut down about 3/4 inch. This gives the strut a bit more leverage on the hatch and in my case makes the hatch stay up nicely. I simply drilled two new holes with a 5/32 I think bit, wallowed the holes out with the bit, and let the stock screws self tap. Haven't banged my head since...
Lift struts frozen? montanaman OEM Tech Discussion 12 December 18th, 2005 22:02
dodge caravan struts Ramsey Tow Rigs and Trailers 5 November 15th, 2005 19:51
Info on gas struts? Roxtar OEM Tech Discussion 1 September 26th, 2005 09:50
Strength of Lift Struts nhrocker OEM Tech Discussion 4 June 24th, 2005 20:33
hatch struts... mikeny59 OEM Tech Discussion 15 January 18th, 2005 22:13
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
