OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
metal windshield trim
So, I had a rather frightening experience today. The top piece of my windshield trim came loose on the passenger side at about 70MPH+30 MPH headwind. Sounded like I had my head in a trashcan and someone was beating on it with a stick. I've looked at it and I can't figure out how to get it back onto it's little clips. Can comeone give me an idea of how it's supposed to work, and a desription or picture of the clip in the windshield frame. I think maybe the clip is broken. I may just RTV the sucker down.
#2
Re: metal windshield trim
They should just push on for the most part. If it came off, I wouldn't be surprised if one of your clips is broken. A windshield repair place should be able to hook you up with some new clips. Sorry, I don't have a pic or a diagram of it. To remove the strips, you need to slide a putty knife or similar tool under the edge and push on the clips. They should give a little and free their grasp of the trim.
#3
yeah, I think the clip is broken. I'll see if I can't get some new ones. I'll prolly just tape it down for the moment.
#4
http://www.naxja.org/forum/showthread.php?t=42581
This link shows you the shape of the clip retainer for the windshield trim. It comes out if you use some sort of bent hook at about a 90 degree angle - you just push it in along one short edge and it springs back, releasing the trim. To put the trim back it should be a matter of clicking it back in. |
#5
I guess I didn't go back far enough in my search. |
Thread Tools | |
Display Modes | |
Removing metal windshield trim | Chancer | OEM Tech Discussion | 2 | December 24th, 2004 01:12 |
Metal windshield trim | bzdel2441 | OEM Tech Discussion | 10 | November 8th, 2004 04:16 |
Windshield Trim | REDDOGG.XJ | OEM Tech Discussion | 4 | January 1st, 2004 14:09 |
Thanks, new windshield with gasket not trim | 8991XJ | OEM Tech Discussion | 4 | October 12th, 2003 18:39 |
Replacing metal 5 piece windshield molding with new Rubber molding | Frank G | OEM Tech Discussion | 6 | April 30th, 2003 22:14 |
