Old November 6th, 2004, 13:33
bzdel2441 bzdel2441 is offline
Metal windshield trim
I would like to know how to remove the metal windshield trim that there is. I do not want to reuse it so that is not a problem. I am going to be getting a 1 peice rubber gasket along with a new winsheild but I would like to check for frame rot beofre i take it in. Can I just take a pair of plyers and rip the metal off os is there another way?
Thanks
Chirs
Old November 6th, 2004, 13:36
red91's Avatar
red91 red91 is offline
Re: Metal windshield trim
Thanks
Chirs
Use a flathead screwdriver and pop off the trim, its fairly easy.
Old November 6th, 2004, 16:28
PaulJ PaulJ is offline
The OEM windshield design doesn't use a gasket. Are you sure you want to trash the trim?
Old November 6th, 2004, 16:30
red91's Avatar
you can install the newer rubber gasket in place of the F' d up metal dirt catching rust uninhibiting trim.
It's a good thing to do.
Old November 6th, 2004, 16:55
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
The original trim clips attach to little studs in the windshield frame. I found that you can use the rubber gasket without removing them if the windshield is well centered in the hole. If in doubt, and 100 percent sure that you'll never revert to the metal trim, you can break off the little studs with impunity.
Oh, and add to Red's list of annoyances of the metal trim, noisy.
Old November 6th, 2004, 16:57
jjvande's Avatar
jjvande jjvande is offline
what does it look like under the trim...i want to remove it as well, but just for looks.
Old November 6th, 2004, 16:59
red91's Avatar
theres nothing the but the crap you've collected since it left the show room.
taking it off for looks will leave you with nothing.
Old November 6th, 2004, 19:56
NAXJA Member #760
It's full of bees and spiders!... and you cannot retrofit the newer style rubber trim unless you remove the windshield.
Old November 6th, 2004, 20:16
nothing will happen though if I remove the trim though right? I just want to check for rot because i have a leak..Its prob. just a poor seal but it wouldnt hurt to look.
Old November 7th, 2004, 08:08
NAXJA Member #760
If you remove the trim it will not cause harm to the windshield or any new leaks. However, you need to be pretty careful how you do it, because the little plastic clips that hold the trim break easily, especially when they're old and brittle, and it's pretty tricky to get the trim back on, trickier yet if you've distorted the trim. You might find yourself needing a lot of goop to stick it back. It's not uncommon, though, to find rust between the windshield sealing bead and the body, causing a leak, so if you can do it you might benefit from getting in there and checking/resealing. Or of course you could follow the next big dump truck full of gravel down a dirt road, and get it fixed when you put the new windshield in.
Old November 8th, 2004, 04:16
Chancer's Avatar
Chancer Chancer is offline
I spoke to a windshield guy the other day about this - he was pretty rude about the metal trim and how good it was - not. He said that his company always replace the metal trim with the newer rubber strip when putting in new windshields, and added that the metal ones are almost always impossible to refit if you take it off to look for leaks, for example. He also said that the early windshields have to be cut out from the seal in any case, so I'd say it sounds like a good reason to upgrade if you are having the windshield out...
Anyone ever replaced the windshield themselves? NotMatt OEM Tech Discussion 13 July 1st, 2004 13:13
Windshield Trim REDDOGG.XJ OEM Tech Discussion 4 January 1st, 2004 14:09
Thanks, new windshield with gasket not trim 8991XJ OEM Tech Discussion 4 October 12th, 2003 18:39
Metal to metal noise offroadman83 OEM Tech Discussion 4 April 30th, 2003 22:53
Replacing metal 5 piece windshield molding with new Rubber molding Frank G OEM Tech Discussion 6 April 30th, 2003 22:14
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
