Old October 31st, 2004, 11:18
el minator's Avatar
el minator el minator is offline
hazard lights
my hazard lights don't work.... the turn signals work, the fuse looks fine and all of the bulbs are still good.
does anyone know what the problem could be?
Old October 31st, 2004, 14:04
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: hazard lights
What year? On earlier (pre-91) models, there are two flashers, one for the signals and one for the hazard. On later ones, there's a combination flasher. If yours is earlier type, I'd first suspect the flasher or the fuse for the hazard lights, which is also separate (I think).
Old October 31st, 2004, 16:07
el minator's Avatar
Re: hazard lights
it's an '89... is this problem related to the green arrow lights staying on in my gauge cluster? the lights aren't blinking, but they just stay lit when i turn on my headlights.
Old October 31st, 2004, 16:16
Sarge Sarge is offline
Re: hazard lights
Swap the two flasher relays around and see if it fixes the problem. BTW my 1993 uses two also. I could feel the relay click with the blinkers on.
Sarge
Old October 31st, 2004, 16:18
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: hazard lights
The green arrows staying on indicate a poor ground for the parking light/turn signal lamps. The parking lights don't have a decent ground path, so they make their own by back-feeding through the turn signal circuit.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old October 31st, 2004, 21:55
Dave in Eugene's Avatar
Dave in Eugene Dave in Eugene is offline
Re: hazard lights
Check and see if your brake lights are also not working. Brake light fuse powers both. Had that problem with my '87, and although the fuses looked good, one had a blade that was corroded a bit and didn't make proper contact.
blinker to hazard lights shimmy OEM Tech Discussion 13 February 2nd, 2005 19:47
Hazard lights Bronco OEM Tech Discussion 2 October 29th, 2004 22:58
Lights lights and more lights... ghettocruiser Modified Tech Discussion 10 October 29th, 2004 16:55
Back Up Lights - Not NSS coach9119 OEM Tech Discussion 4 January 29th, 2004 13:22
Silverstar bulbs XJguy Jeep Street and Performance 20 December 26th, 2003 16:46
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
