Old October 29th, 2004, 18:23
Bronco's Avatar
Bronco Bronco is offline
Hazard lights
My turn signals have been working erratically (some days they work other days no) for a month or so. Today at lunch I was fooling with them (they worked today) and I turned on the hazard lights and when I turned them off the left side stayed on, even if I turned off the ignition. I had to pull the blinker can thing from the fuse box to stop it. I’m afraid the problem is with the switch in the column because the hazard light switch feels funny and I’m thinking if the problem was with a turn signal it would go off with the ignition (only the hazard lights stay on). I don’t really know what to do next. Is there anything to do before pulling the whole column apart?
Can anyone help me?
Old October 29th, 2004, 21:07
8Mud's Avatar
8Mud 8Mud is offline
Re: Hazard lights
The hazard knob, has screw in the middle and is notched so it doesn´t twist on the stem. Slip it in the notch and tighten it down and see what happens. May help.
Grounds in the lighting system will really mess with you. Good place to start is the ground behind the windshield washer resivoir, on the early XJ´s. A bad ground at a bulb (or burnt out bulb) will mess with the turn blinker.
Old October 29th, 2004, 22:58
Bronco's Avatar
Re: Hazard lights
I’m pretty sure it spins freely on the screw. Is that bad?
blinker to hazard lights shimmy OEM Tech Discussion 13 February 2nd, 2005 19:47
Lights lights and more lights... ghettocruiser Modified Tech Discussion 10 October 29th, 2004 16:55
Replacement Backup Lights Wiring Question gpthrlz Modified Tech Discussion 6 September 27th, 2004 06:15
Back Up Lights - Not NSS coach9119 OEM Tech Discussion 4 January 29th, 2004 13:22
Rock Lights Cresso Modified Tech Discussion 12 April 15th, 2003 22:39
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
