Old July 5th, 2022, 10:55
NeuralF NeuralF is offline
Clutch kit for 1992 XJ 2.5
Should I buy this 1993 kit: https://www.summitracing.com/parts/l...okee/year/1993
or 1992 one?
https://www.summitracing.com/parts/l.../1992#overview
XJ was build in december, 1992. It would be strange to take the gearbox apart just to check it out.
Old July 5th, 2022, 13:09
jeep ride's Avatar
jeep ride jeep ride is offline
Re: Clutch kit for 1992 XJ 2.5
Buy both send one back ?
Old July 5th, 2022, 15:54
Anak's Avatar
Anak Anak is offline
Stranger
Shipping to and from Australia is probably less than ideal.
What is the difference?
Only thing I noted was that one comes with a pilot bushing, the other doesn't.
How about contacting a dealership, giving them the VIN and asking them which side of the year break fits yours?
Old July 6th, 2022, 02:43
Thanks everyone. Yes, it makes no sense to send back. The dealer's response will take forever. The main difference is hydraulic tubes.
My mechanic told me a '93 should fit. Wish us luck.
Old July 7th, 2022, 06:51
Anak's Avatar
Stranger
I recommend you also order a real throwout bearing, like a Timken or SKF.
The ones that come with the kits are garbage and will fail on you suddenly and hard.
Old July 7th, 2022, 10:54
DustyWagoneer's Avatar
DustyWagoneer DustyWagoneer is offline
One thing that is VERY important too, is the fact that per the FSM the Flywheel has to be replaced. It should not be resurfaced.
The Flywheel has a concave face, and when machined it makes it flat. Your clutch will not last if machined (ask me how I know?).
One more thing.
I did this to my 93 to get that hydraulic throw out bearing:
https://www.motortrend.com/how-to/16...inder-upgrade/
Old July 11th, 2022, 11:40
Thank you guys. Forgot about the flywheel and didn't know Luk could have quality issues.
AX15 clutch noise after new clutch kit installed. Jumpnj OEM Tech Discussion 3 January 6th, 2018 07:59
Hard clutch pedal and clunk; Before and after new clutch... SouthSeaPirate OEM Tech Discussion 9 January 29th, 2016 15:13
doing a clutch and tranny next weekend..hydraulic clutch lines....help! xjridin OEM Tech Discussion 4 July 14th, 2008 05:39
4.0 Clutch with Brand new Centerforce Clutch disc rav For Sale: Private Party Only. XJ ITEMS ONLY 4 May 11th, 2004 10:41
5 speed trans, clutch flywheel, clutch cyl rsalemi For Sale: Private Party Only. XJ ITEMS ONLY 2 April 28th, 2004 05:29
