Old September 2nd, 2009, 19:14
lsc910 lsc910 is offline
Another dumb a** lift question
Hello everyone I was given a pro comp lift that was supposed to be a 3'' kit but It was an add a leaf and I'm putting together a Dakota bastard pack. My question is about the lower control arms that came with the kit, They are 16'' center to center and I'm wondering if that is going to enough for a 4.5'' to 5'' kit or do I need longer ones? My next question would have to be about the bastard pack and the keepers or clamps that hold the springs from fanning out. If I was to make a u shaped retainer like thew ones that come on some lift springs ,how do I secure them to the spring without damaging the hardened spring can you weld them on? Thanks for the info.
Old September 2nd, 2009, 19:32
builder builder is offline
I have not Confirmed, or I used a BAD email Addy
Re: Another dumb a** lift question
Yucca-Man: Rubicon Express RE9900 Drop Brackets this gives approximate LCA lengths, when shops do them they use a rivet, they drill a hole them reem it so when the rivet is driven it lays flat so the leaf above slides over it. you can do this with a countersunk bolt or screw.BDS sells the clamps ready to go for 24.00. a unibit to reem it until it sits flat may be needed.
dumb question lsc910 Modified Tech Discussion 13 August 27th, 2009 19:05
Sorry I have a dumb question FlexdXJ OEM Tech Discussion 11 May 19th, 2008 05:49
dumb question NickD OEM Tech Discussion 4 January 8th, 2007 22:03
Dumb question riverfever Non-Tech / Off Topic 21 May 9th, 2005 09:18
dumb question ladywolf NorthWest Chapter 11 April 8th, 2004 13:43
