jeepster_259
- West Palm Beach, FL
So, what are the causes of low voltage to the fuel pump? I searched but couldn't find anything for actual causes of it.
The reason I ask is that I recently turned my jeep into a submarine and my fuel pump ended up dying for whatever reason as I was leaving the trail. Got towed home, put in a used fuel pump I had lying around and it started right up and would idle for 5-10 min. fine and then die. It would restart, but die immediately. After sitting for a couple hours it would start and idle then die, and then start and die immediately, same thing. I started getting codes for low fuel pump voltage and short circuit in relay.
I swapped relays and put in a brand new Bosch fuel pump with new filters and cleaned the gas tank last night (had some sand in it) and re-installed everything. I started it and let it idle for a good 10-15 min. and it didn't die yet. I didn't try driving it b/c I didn't want to risk breaking down on the side of the road. I'm still getting the codes for low voltage and short circuit though.
I'm going to d/c the battery and clear the codes and let the jeep run some more tonight, maybe the codes are just still stuck in the memory.
Anyway, long story short, I want to find out what to check that would casue low voltage at the fuel pump. I've checked the harness at the pump and it all looks good.
It's a 98, 4.0, AW4.
