ZPD
- Modesto Ca.
Hey, I just recently installed a new set of VDO guages in my 67 mustang. The past few days I have noticed that my volt guage shows that I have around 13 volts at idle and when I rev up to 2K or 3K it goes up to 16+ volts.
So on my way home from work I picked up a new voltage regulator but that didn't solve the problem. Upon further investigation I noticed that there was not a wire connecting to the "I" terminal in the connector. I couldn't see a wire anywhere that was cut or anything. Is this my problem? Or is there something else? Also there are two wires that come out of the "A" terminal and one of them is just cut off a few inches away from the connector. What wire should connect to the "I" terminal? and what is this extra wire at the "A" terminal?
Also I did verify this with my voltmeter and my guage is correct. Any ideas?
