redneckboarder
- cumberland RI
the chain in my 231 which was out of a 91 was skipping so i got a good deal on a case out of a 96 xj
the case went in fine, i got everything hooked back up except the speedo sensor which isnt a big deal since its a trail rig the front shaft seemed to fit ok but the rear shaft was now about 2" too short, i measured everything and it appears that the cases are the same length, the splines line up but bottom out before i can get the rear u joint in
if anybody can help id be very thankful
im gonna go check right now and see if anything moved backwards
