Old June 12th, 2019, 21:04
moparcyco moparcyco is offline
Psc big bore box swap issues
Anyone here running one? Had a stock box on 37's tons etc. Finally gave it up couldn't really turn locked. So put a modified wj pump on helped a bunch. So I bought the Psc box supposed to be a lot more powerful than stock right? put the first one on turned great to the left but anything going back to the right had a horrible sound. Called Psc they had me send a video they said definetly a hydraulic issue. sent me another box installed this one now it makes the noise both directions. The pump does not make a sound could I have lost pressure or are these things junk?
$800 is a lot to pay plus I'm using swepco fluid at $10 a quart this is getting expensive. Anyone run into this before? Thanks
Old June 13th, 2019, 06:20
sandfreestyle sandfreestyle is online now
Re: Psc big bore box swap issues
is this before or after getting the air bubbles out?
Old June 13th, 2019, 07:12
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I'm going to guess that the pump is at fault here.
PSC boxes are def not junk.
Old June 13th, 2019, 08:16
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
The issue is with the big bore box, it requires more fluid from the power steering pump, which is why it's whining when you turn. Do you have a video of the sound it's making?
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old June 13th, 2019, 08:28
Black1990jeep Black1990jeep is offline
Your pump maybe the issue. many makers suggest a more powerful pump or at least a stock one that is up to the job when going to a bigger steering gearbox. PSC has a good reputation. AGR on the otherhand sells junk, the owner lies to you on the phone, if you can even get a hold of him.
I suggest trying a new or upgraded pump eventually. see what PSC says about the pump. yoru pump maybe on its last legs for instance, not enough umph to work with a bigger gear box.
Old June 13th, 2019, 20:36
The pump is a 2001 wj pump from 4.7 with the hydraulic fan. has xj pressure fitting drilled to 5/32. I was going to wait and try going to 3/16 but I've been told that is absolute overkill. Called Psc today they gave me a list of things to check. If you use a stethoscope you can hear its the box. even pulled the pitman and cycled the wheel with no resistance with the scope you can still hear it in the box. We also had it on a hoist with the pitman disconnected and cycled the steering by hand there is nothing binding. I am 100% sure its the box. they say there is no way I could get two in a row bad. I work in Auto parts guess what happens all the time.
I just hope there service is as good as everyone says. And they will help me. I'll let you guys know what happens.
gauge swap issues Tann120 OEM Tech Discussion 5 July 27th, 2015 09:31
Issues after steering box swap 98cherokeedriver OEM Tech Discussion 2 April 10th, 2012 12:45
AW4 swap issues DutchVDub Colorado Chapter 34 September 28th, 2011 15:35
231 swap issues redneckboarder Modified Tech Discussion 3 October 12th, 2009 11:00
D30 Swap - ABS issues? mfascuba OEM Tech Discussion 5 November 3rd, 2008 17:38
