Old February 10th, 2019, 19:12
Lanser1999 Lanser1999 is offline
5 pound fire extinguisher mounting
So I decided to go with a 5 lb fire extinguisher and was just looking for some ideas for where to mount this sucker. Anyone have any ideas?
Old February 11th, 2019, 07:26
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 5 pound fire extinguisher mounting
Someplace where it won't break loose and whack you in the back of the head.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old February 12th, 2019, 15:40
JTJersey's Avatar
JTJersey JTJersey is offline
I keep a 2 1/2 lb under the rear seat, along with duct tape, spare radiator hoses and the OEM jack. Don't think there's room for a 5 pounder there though.
Old February 12th, 2019, 16:04
devildog0's Avatar
devildog0 devildog0 is offline
5lb is pretty large. I have a smaller dry chem mounted in the little cubby hole in the cargo area.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old February 12th, 2019, 17:14
Might just make my own mount for in the rear hatch.
Old February 13th, 2019, 11:18
Greenspan's Avatar
Greenspan Greenspan is offline
Yeah there may not be a straightforward answer for a 5lb'er. Google 5lb Fire Extinguisher mount and use that to attach it to something solid in the Jeep.
For my 3lb Extinguisher I used this:
https://www.amazon.com/dp/B071DX3H6G/ref=cm_sw_em_r_mt_dp_U_-XgzCbCMF56DJ
It was easy to mount onto my tire carrier. I'd recommend if you have a bar or something solid to strap it to.
Old February 13th, 2019, 11:42
Scrubber3 Scrubber3 is online now
So after working EMS for a few years, it occurred to me that having a fire extinguisher mounted in an area easily accessible to the driver while buckled was the best option. I plan on mounting one to the lower portion of the center console
Old February 13th, 2019, 19:02
devildog0's Avatar
As a FF/EMT I've thought of this as well and after many times trying to find out how to mount even a small extinguisher upfront where I could reach it without interfering with the seat's movement, my legs, or my passengers I gave up.
I think the only thing I might be able to pull off is one of those aerosol can type extinguishers between the door sill and seat.
Old February 13th, 2019, 20:24
Good point. Maybe one small up front and a larger one in the rear.
Old February 14th, 2019, 08:34
Anak's Avatar
Anak Anak is offline
Stranger
I decided quick access to the fire extinguisher is more important than movement of the driver's seat (The Bride is pretty tall too) and so I mounted my extinguisher right up against the front of the driver's seat. That makes for very easy, quick access.
If movement of the driver's seat were a priority I think it would be possible to fabricobble a mounting bracket that would travel with the seat.
Baby it's cold outside.
Old February 14th, 2019, 13:53
Rockwood Rockwood is offline
Back in my racing days, even with onboard fire systems, we always attached a 2.5lb extinguisher to the floorboards under the driver's knees.
Old February 16th, 2019, 05:12
denverd1 denverd1 is online now
Bleepingjeep has a quick release mount. Says it works with any extinguisher
https://store.bleepinjeep.com/produc...guisher-mount/
Ill likely put in front of or behind passenger seat
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old February 16th, 2019, 07:40
trippled trippled is online now
This is exactly how mine was. I never had issues up there, it's really not in the way.
Old February 16th, 2019, 13:50
jmg222 jmg222 is offline
you want it somewhere easy to reach, where it won't kill you if you hit your head. I bought a quick-release mount, and mounted one each to the passenger and driver side seats. I used h3r halon.. granted.. I have 2.5 lb units in the front, mounted 5 pound units in the rear .. mounted the brackets to the plastic molding over the rear wheel wells (got rid of those mounts after getting a roll cage, now just have the extinguishers mounted on the cage)
Daily drive: 2018 Jeep Grand Cherokee TrackHawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: '19 ZZ6 350 sbc, 405HP/405 lb-ft; holly performer EPS, Terminator EFI, headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old February 17th, 2019, 12:25
You plan on rolling up to a house fire?
5-B:C Auto Fire Extinguisher 2 lb. 10 Bux Original_MudButt Tools and Garages 0 March 15th, 2016 07:28
Fire Extinguisher???? wheeling365 Modified Tech Discussion 6 October 7th, 2010 11:29
mounting a fire extinguisher Gnat5680 OEM Tech Discussion 10 July 26th, 2006 20:05
fire extinguisher cw50must Tow Rigs and Trailers 5 April 13th, 2006 14:59
Which Fire Extinguisher and where to mount in a 97+ Red97XJ Modified Tech Discussion 34 December 2nd, 2005 18:06
