89Cherokee95
- BC Canada
I have a 1989 jeep cheroke that Backfires, misfires, runs really rough for the first few minutes after startup, sometimes smooths out a bit but not completely and is drivable. cylinder 2 seems to be dead, unplugged the injectors one by one to see if it changes the way it runs, it bogged down on all but the number 2 cylinder. It goes through a quarter tank of gas in about 30km, I thought it might be the fuel pump dying as it is very loud and erratic sounding, I have a new one to replace it on order. I just wanted someone with more experience to help me out.
If it helps at all, I can post a video of how is sounds when its running to give you a better idea.
So far, I have replaced the
distributor cap and rotor
ignition control module
fuel pressure regulator
vacuum lines (re-routed/repaired)
exhaust manifold
O2 sensor
crankshaft position sensor
ran a test on every sensor I could find (think I got em all) - all tested GOOD
fuel filter
exhaust manifold
O2 sensor
fuel filter
