Old November 17th, 2006, 00:45
mvella's Avatar
mvella mvella is offline
95 stright six oil pressure sending unit
ok so i have an 89 cherokee limited with a 95 4.0L high output stright six in it. the oil pressure was pinged right when i stared the car. now i wiggle the wires on the oil pressure sending unit and it was fine but i tried it again and now it wont work. i think the sending unit is busted. what do you think. ohh and what kind of sending unit will fit on there is it just the one for the 95 engine or can i use the one from an 89??? please help a jeeper in NEED!
Old November 17th, 2006, 02:18
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Re: 95 stright six oil pressure sending unit
I think the sending units are exactly the same on all 4.0 engines so just buy a new one.
Old November 17th, 2006, 02:34
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
No they arn,t.IIRC the terminal end changed in 96 .Year groups 84-91 and 92-96 my book shows the 98 and 99 as different too.
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old November 17th, 2006, 06:06
scorpio_vette's Avatar
scorpio_vette scorpio_vette is offline
i don't know the year break, but i have an 89, 94 and 95 cherokee 4.0L in my garage. the 89 is completely different from the 94 and 95. the 94 and 95 is the same.
if you know what year the engine is, just buy all your engine replacement parts for that year jeep.
Old November 17th, 2006, 06:53
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
The year break is 90/91. You need whichever version matches your instrument cluster, not the engine itself. Assuming the instrument cluster is also updated to 95 you need 91-up. If you managed to make the 95 engine work with the original instruments, stick with the original type.
Old November 17th, 2006, 07:47
the oil pressure sending unit from the 89 won't fit into the spot where the 95 has it's oil sending unit. so i'm pretty sure he found some way to adapt it.
how about this.........take the sending unit off of your engine and take it to the parts store. then have them pull a sending unit for an 89 and a 95 and see which one matches.
Oil Pressure Sending Unit krizgawd OEM Tech Discussion 10 February 2nd, 2006 23:41
Oil pressure sending unit replacement? Rusty from Cleveland OEM Tech Discussion 13 December 22nd, 2005 18:00
Is this the oil pressure sending unit? iBran OEM Tech Discussion 7 May 26th, 2005 23:04
broke off oil pressure sending unit VTJeepr OEM Tech Discussion 7 January 16th, 2004 19:17
oil pressure sensor sending unit jeep_cj8 OEM Tech Discussion 5 June 15th, 2003 18:24
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
