gasket set
green95xj
ma
I have a 97 xj that I pulled the motor due to oil leaks. I was wondering if there is a gasket set out there for the 4.0 includeing the valve cover gasket,oil filter adapter o rings,oil pan gasket,rear main seal,and a timing chain cover gasket.I have searched and have come up with nothing. Any help would be greatly apreciated. Thanks
the adapter o-rings you'll have to buy separate from the Stealership.
