NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
I am getting ready to pull the trigger on a set of Rough Country flex upper and lower control arms. Any body running them that can give some feedback? I could not find much searching. Thanks
Depending on what your future plans are, you might want to hold off until you can afford a full lift kit. I recommend going long arm but short arms with drop brackets work too. You will be money ahead in the long run to save and do it with a full kit.
Either way I need control arms right away. My bushing are shot im my stock arms and I don't want to spend money on stock parts to fix it. I will most likely go with d-brackets when the time come.
Thanks for the offer John. But if I change them out if will be for aftermarket ones. While I fix this problem I want to make small headway into setting the jeep up right for the trails.
rockhead, I'd take John up on that offer. Swapping LCAs is easy, I can do em in less than 20 minutes even on rusty northeast jeeps. UCAs are a bit tougher since they use those blasted tag head bolts.
Just remember to only do one control arm at a time and you can get it all done over a long lunch break.
It is actually between Ironman and Rough Country right now. With the rough country I can get flex joints for about the same price as rubber bushing with ironman.
