1990 Wagoneer Limited- lower control arm mount broken
Kyle_South_Park
Hi everyone after replacing the fender on the jeep. :rolleyes: I found out that my lower control arm has broken from the mount how serious is this. i have been driving it like this for two weeks now without even knowing I think I hit a big rock and broke it off. The only symtom was pulling when braking hard Is this going to be crazy expensive to fix arggg
thanks
zac
chances are the mount can be welded back into place-- I't add some reinforcement if you go that route-- as the metal has been probably lost some integrity.
rustys has some heavy duty mounts try
them its a good upgrade if you wheel about $60
