Old September 14th, 2004, 23:40
RedBluff's Avatar
RedBluff RedBluff is offline
Brake Fluid in the Power Steering Reservoir
88 Cherokee Laredo
It's nuts but it happened.
I should have checked the fluids before I bought it.
The shop flushed it out and refilled it correctly.
My question is should I expect leaks in the near future?
It doesn't makie as much noise as it used to but I'm pretty sure it has an air leak as I do notice it gets foamy when it's hot.
Should I try that Lucas PS leak plugger?
Thank you in advance,
RedBluffBoy
Old September 15th, 2004, 19:07
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: Brake Fluid in the Power Steering Reservoir
I wouldn't put any leak stopper in unless it is leaking. Brake fluid shouldn't affect the seals in the pump, so if it didn't clobber the vanes and kill the pump, you're probably all right. I'd wait and see what happens. Saginaw pumps are pretty robust, so luck may be with you.
Old September 15th, 2004, 19:56
RedBluff's Avatar
Thanks Mat, so far so good.
Old September 16th, 2004, 15:18
massxj's Avatar
massxj massxj is offline
a friend of mine put power steering fluid in his brake master and within a few weeks all the seals in the master and the prop vale sweeled up to twice the size but where your the other way around i dont know
Old September 16th, 2004, 21:43
RedBluff's Avatar
I heard someone used Brake Fluid to "plump up" his door seals.
Brake & Clutch Fluid Facts Jagmeister OEM Tech Discussion 2 July 26th, 2006 07:39
Power Steering Fluid Filter MrShoeBoy Modified Tech Discussion 11 July 19th, 2004 20:25
power steering fluid capacity CaptTrev OEM Tech Discussion 3 March 16th, 2004 16:59
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 14:51
power steering fluid damaging to hoses? JGXJ OEM Tech Discussion 15 June 28th, 2003 10:15
