Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
  #16
Old July 11th, 2020, 19:53
Anak's Avatar
Anak Anak is offline
Stranger
Re: NO MORE JEEPS!!
Thank you for the wishes of good luck. I may have just solved my battery charging issue: https://naxja.org/forum/showthread.php?t=1159228
If it turns out to have been that simple that will have been an easy fix.
And you are spot-on WRT the axle-shafts. I have U-joints and the 242. That was a relief. I didn't know they had yet another T-case. I was afraid I might be up the proverbial creek with the shift linkage.
Old July 15th, 2020, 16:25
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: NO MORE JEEPS!!
I believe all the I6 ZJ 4Wd had the 242.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old July 16th, 2020, 05:50
OverlandZJ's Avatar
OverlandZJ OverlandZJ is offline
NAXJA Member # 101
Re: NO MORE JEEPS!!
I had a 95 for a few years with a 231 behind the 4.0L.. although pretty rare optioned that way.
I really like the ZJ platform, should have moved to one years before. The XJ was fun all those years but the ZJ is hands down more comfortable.
Old August 22nd, 2020, 20:14
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
Gotta love the learning curve.
I tasked Varmint #1 with programming and installing a third brake light flasher.
Programming, no problem.
Installation?
He thought he had broke the whole brake light system. Not only was the third brake light not working, but the passenger side brake light was out too. Poor kid was all confused and sure he had messed something up but good, yet had no idea how he could have.
In steps Dad.
Have you checked the bulbs?
Found that all three bulbs for the third brake light were out as well as the passenger brake light. Four new bulbs and everything works just fine.
Varmint #1 said "Lesson learned. Check status of systems before starting work."
FWIW, I had them check the rest of the bulbs on the vehicle. Found that both side markers in the rear tail lights were out as well as both front turn signals.
Now I just have to figure out how to pull the front turn signals. Not as obvious as on an XJ.
Old August 22nd, 2020, 20:20
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Location: Upstate NY-live; Death Valley-play; Hawaii-working on it
Re: NO MORE JEEPS!!
That many bulbs out? Did they hook the thing up to 220V?
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2021
Not a member? Become one today, and help support YOUR club.
Old August 22nd, 2020, 20:50
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
I think they have accumulated over time.
Lets just say the P.O. was not into maintenance.
Old August 24th, 2020, 15:41
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: NO MORE JEEPS!!
It goes like this....
Customer..."my headlights quit working, must be a switch or fuse".
Me..."probably just burned out"
Customer...."no, they both couldn't burn out at once"
Me..."right, one burned out first and you didn't notice because you still had one"
Happens every time
The MAC-10 submachine gun was practically designed for housewives.
Old August 24th, 2020, 19:09
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
Had to go questing online to figure out how to get those turn signals out so we could get to the bulbs. Chrysler did a nice job of hiding the hardware and making it inconvenient.
I don't think the bulbs burned out though:
Filaments look fine, but the contacts are all carbon on one side. Whiskey Tango?
Auto parts store sold me on "bulb grease". I am thinking it is closely related to blinker fluid. I always figured that crud which had to be cleaned off from old bulbs was the accumulated deposits left behind by old blinker fluid that had evaporated away.
It seems to me these fancy new modern bulbs with their plastic bases are in no ways near as good as the old school bulbs with brass bases. Just another way the bean counters have messed up something that worked just fine.
At the very least they could have made them easier to access and change.
Oh well. After replacing a total of 8 bulbs The Varmints now have all the exterior lights working properly.
Old August 25th, 2020, 00:12
maxbraketorque maxbraketorque is offline
Re: NO MORE JEEPS!!
Assuming the light socket is not trashed, some dielectric grease should prevent any further corrosion that triggers the arc melting.
Old August 25th, 2020, 08:05
JohnX's Avatar
Sarge <3 Ben
Re: NO MORE JEEPS!!
Clean the heck out of the contacts. Use a pick tool to bend then in...tighter fit. And yes, use the dielectric grease. The grease does 2 main things...prevents corrosion from moisture and helps disapate heat.
Rate This Thread:
I may be done with Jeeps oldbill OEM Tech Discussion 6 May 3rd, 2014 20:34
My Jeeps XJ-ARNIE Midwest Chapter 21 January 21st, 2010 20:46
ANY MPG READERS FOR THE OBD1 JEEPS? OR CAN INTALL OLD MPG READ OUTS FROM OTHER JEEPS? 95cherjustin OEM Tech Discussion 7 September 21st, 2008 22:37
Why I like Jeeps XJRunner Non-Tech / Off Topic 4 November 5th, 2006 20:19
New to Jeeps WV Jeeper Modified Tech Discussion 14 December 17th, 2004 22:10
