Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
Old July 6th, 2020, 19:48
Anak's Avatar
Anak Anak is offline
Stranger
NO MORE JEEPS!!
That's what she said.
Repeatedly.
Hmm.
Maybe this isn't a Jeep.
It's not an XJ at least.
Or, um, "It's not for me. It's for The Varmints."
At any rate, I have another project.
Supposedly it needs a new battery. This one doesn't take a charge. Methinks that has something to do with the fact the volts gauge reads so low, and doesn't vary the least with RPMs. My bet is that the voltage regulator in the ECM has kicked the bucket.
But for $1,000 price tag I think I can cope with that detail.
Brand new set of tires, and "needs an alignment" probably means I need to rebuild the front suspension.
But I don't think this vehicle has ever been wheeled. Nice and straight underneath. No interesting dents or scrapes. I suspect it was the grandparents' tow rig behind their RV. Body is almost perfect. Lucky for The Varmints there is a scrape behind the right side rear door, so they don't have to bear the brunt of having put the first dent in it.
Old July 6th, 2020, 22:35
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
NO MORE JEEPS!!
Nice. 4.0 or 5.2?
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old July 6th, 2020, 22:38
sdspearo's Avatar
sdspearo sdspearo is offline
Re: NO MORE JEEPS!!
That's a nice looking ZJ, especially for a thousand bucks. We have its twin as our grocery getter ('97 ZJ) except yours looks cleaner. You plan on keeping it unmolested?
'96 XJ: Locked up D44's on 35" Milestar Patagonia's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Atlas 5.0, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old July 7th, 2020, 06:26
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
It is the 4.0. That has been one of my requirements when looking at ZJs.
I would like to say I plan to keep it unmolested, except for the fact that I intend to put Varmints behind the wheel. I have no doubt they will molest it somehow.
But there are no plans for a lift or any major mods.
OTOH, I am not going to try to keep it totally stock either. The first thing I ordered for it is a Boostwerks NP242 shift linkage--because it took me several minutes and countless tries in order to finally get the T-case into neutral so I could tow it home without removing the rear driveshaft. I have also ordered an external voltage regulator kit for the probable finding that there is nothing wrong with the alternator. Odds are good it will get Brown Dog motor mounts. It may well get an aftermarket track bar and double shear mount. A headlight harness with relays is probably in its future. Those are the only things I can think of that I am likely to change from stock.
I need to figure out what all is needed for the front end--bushings? Tie rods? Ball joints? Those will get replaced with Moog or Spicer parts as needed. I will probably replace all the U-joints in both driveshafts and the front axle shafts with Spicer U-joints. Probably the centering ball too. Change all the fluids (engine (incl. conversion to Cat ELC), trans, T-case, diffs and brake system), new battery cables (there will be another small mod--convert to military terminals) and the interior needs attention (console flops around, seats are a fiasco, no knob for headlights, broken handle for hood release--generally lots of stupid stuff). But the AC works.
And Varmints #1 & 2 are going to get their hands really dirty learning how to do all this work. I just have to figure out how to get them into the junkyards so they can learn how to pull parts without breaking things.
Old July 7th, 2020, 08:19
Piece of Fish!
NO MORE JEEPS!!
Unless the front shafts have already been swapped, they are cv shafts. You can use xj shafts though.
Old July 7th, 2020, 09:11
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: NO MORE JEEPS!!
They dont check ID, just say they are 16.
The MAC-10 submachine gun was practically designed for housewives.
Old July 7th, 2020, 13:40
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Re: NO MORE JEEPS!!
I'm sure she knows by know that your listening ability is a bit... creative.
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old July 7th, 2020, 18:16
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
Thank you for that tip. I highly doubt they have ever been changed. Good to know before I get surprised trying to do something with them.
I am not aware of any way of servicing CV joints. I take it you just do an exchange on them?
I am sure I am going to find all sorts of details that are different from an XJ. Among others, it appears the motor mounts are another animal entirely. They look more like the motor mounts on my Cummins. Hopefully that means they are a good design.
OTOH, what was Chrysler thinking on the subject of fuel filters? The ZJ fuel filter is not serviceable according to Napa. Supposedly it is integrated with the pump assembly. The stealership was willing to order something for me for $180. I am not sure if that was to be an entire pump assembly or something that replaces whatever is integrated into the pump assembly. At $180 I figured that was more than I intended to spend for a fuel filter.
Lots of new details to figure out.
Old July 7th, 2020, 18:17
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
I can't imagine what you could be talking about.
Old July 8th, 2020, 08:09
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Re: NO MORE JEEPS!!
I think NAPA is full of crap. It's one bolt and 2 snap lines to change out the fuel filter.
https://www.youtube.com/watch?v=jueraGcITuU
I have a 96 ZJ that I've owned for 21 years that has been sitting since 2017 that I am resurrecting. I just did ball joints, tie rod ends, brakes, shocks, coolant flush and fill, radiator hoses, plugs, wires, oil change, and valve cover gasket. Fuel filter is the last thing on my list to complete.
They are as simple to work on as the XJs are.
EDIT - I may be wrong. I'm reading now where they only did the external fuel filters though the '96 model year. NAPA may be right in your case. I didn't notice where you mentioned your model year.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old July 8th, 2020, 11:54
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
Mine is a '97.
Old July 8th, 2020, 12:16
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: NO MORE JEEPS!!
Well I have a 96 and it has a fuel filter, 2 98,s and the 99 have none,,except IN the tank.
Lots of newer vehicles don't have filters.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old July 9th, 2020, 10:19
Dubster Dubster is offline
Re: NO MORE JEEPS!!
I would like to know how the installation for the T-case shift linkage goes. I have one for my '99 XJ that I haven't installed and need to.
Old July 9th, 2020, 12:03
Anak's Avatar
Stranger
Re: NO MORE JEEPS!!
The one I put in my XJ went fine.
Well, except for a factory nutsert that just spun in place. But that wasn't Boostwerks' fault.
Taking out the factory stuff was more work than was the installation of the new parts.
Old July 10th, 2020, 06:55
OverlandZJ's Avatar
OverlandZJ OverlandZJ is offline
NAXJA Member # 101
Re: NO MORE JEEPS!!
I also had a twin to this Jeep.. my last build that i journaled here.
You may have ujoint axleshafts, iirc my 98 with 242 utilized them. Fulltime 249's came with the cv's in my experience. My latest, a 94 with V8/249 had torn boots, i ordered new boots and they came with grease. Inspected cv's for smoothness in it's rotation, greased up and installed new boots.. been fine but it only had 84K miles on them.
Best of luck with this..
Rate This Thread:
I may be done with Jeeps oldbill OEM Tech Discussion 6 May 3rd, 2014 20:34
My Jeeps XJ-ARNIE Midwest Chapter 21 January 21st, 2010 20:46
ANY MPG READERS FOR THE OBD1 JEEPS? OR CAN INTALL OLD MPG READ OUTS FROM OTHER JEEPS? 95cherjustin OEM Tech Discussion 7 September 21st, 2008 22:37
Why I like Jeeps XJRunner Non-Tech / Off Topic 4 November 5th, 2006 20:19
New to Jeeps WV Jeeper Modified Tech Discussion 14 December 17th, 2004 22:10
