Old January 15th, 2008, 11:47
nates94xj nates94xj is offline
Older Warn Trans4mer brush grille guard
Does anyone have an older Warn Trans4mer grille guard? I picked up one that only has 4 mounting points. Did they come that way from Warn? Will this thing really handle an 8000lb winch? If so, anyone have installation pics?
Other than that, it's pretty burly, but I might just sell it and buy an aftermarket bumper or maybe just a front hitch instead. Thanks.
Old January 15th, 2008, 11:50
87manche's Avatar
87manche 87manche is offline
Re: Older Warn Trans4mer brush grille guard
if it doesn't extend at least as far back to the factory tow hooks then I wouldn't put a winch on it.
I bet that Warn intended that unit to be bolted up with the factory tow hook brackets.
Old January 15th, 2008, 12:14
NorCalChris NorCalChris is offline
do you have any pics of your unit?
Old January 15th, 2008, 12:32
Not for public consumption
I'll get some pics of the mounting bracket on later today
Old January 15th, 2008, 16:36
Here's some pics of the mounting points:
Old January 15th, 2008, 22:51
look familiar to anyone?
Old January 16th, 2008, 14:11
bump
Old January 16th, 2008, 14:28
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I don't see any mounting point there worthy of recovery gear. Trying it will end badly.
Old January 16th, 2008, 14:32
Ramsey's Avatar
Ramsey Ramsey is offline
I had one and it worked great, still using the mounts for my bumper that I have now. However, I think mine had more tie ins than that one. 8 from the stock bumper mounts(99) and then 4 on the crossmember.
Old January 16th, 2008, 16:22
I talked to Warn, pretty good customer service actually, and they sent me a PDF with part #s and install directions. For around $40 I can get brackets with 10 bolt on spots, as opposed to the two on this hillbilly bracket it came with. At least I only paid a $100 for this thing.
Old February 20th, 2008, 20:41
Mechanic_Dave's Avatar
Mechanic_Dave Mechanic_Dave is offline
Would you happen to have that PDF file? I have the same unit. I wouldn't mind getting those brackets as well.
Old February 20th, 2008, 23:13
PM me your email address and I'll send you the PDF. The brackets are no longer available. They were pretty whimpy anyways. A machinist owes me a favor so I'm having him fab me up beefier pair that I designed. I'd advise getting tow hook brackets and bolting through them to the brush guard bracket. When you see the PDF it will make sense. Warn only rated this carrier to 6000lbs.
Old June 3rd, 2008, 10:16
AlabamaDan's Avatar
AlabamaDan AlabamaDan is offline
Does it look like this:
[img]http://i209.photobucket.com/albums/b...o/100_0738.jpg[/img]
[img]http://i209.photobucket.com/albums/b...o/100_0737.jpg[/img]
Old June 3rd, 2008, 10:53
IGOCOMMANDO's Avatar
IGOCOMMANDO IGOCOMMANDO is offline
I had one and hated the way it hangs so low. So I cut the lower arms off and welded it to a bumper that I built. I also took the bolts out that hold it together and welded it up. It is quite beefy now. I have stalled my 9k winch in it and it's still hanging together.
Old June 3rd, 2008, 16:22
Originally Posted by AlabamaDan
That looks like the same model unit but made for a different truck than the XJ, my guess. You're missing the bottom brackets.
FS(NY): WARN Trans4mer Grill Guard BRAND NEW **PICS**/ FS: 99 XJ FSM TOO!! 99XJSport For Sale: Private Party Only. XJ ITEMS ONLY 5 June 10th, 2007 22:58
Brush Guard & Grille Guard 88-xj-laredo NAC Classifieds 2 May 4th, 2007 20:46
New York Introduces Bill to Ban the Use of Grille/Brush Guards penberth Non-Tech / Off Topic 7 April 23rd, 2006 00:37
Ogden, UT. Any interest in a Warn Trans4mer winch mount? TRNDRVR For Sale: Private Party Only. XJ ITEMS ONLY 6 September 7th, 2003 15:32
