Old November 20th, 2020, 11:08
Josephksapp Josephksapp is offline
Fuel injectors keep firing
I recently put a new Comp Cams cam, clearwater big valve head, and 4 hole injectors in my 2000 xj. My problem no is that when the key is in the on position with the engine off the injectors continue to fire.
Sent from my SM-N975U using Tapatalk
Old November 20th, 2020, 11:29
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Fuel injectors keep firing
Are you describing that the PCM keeps sending injector pulses to the injectors, or do you mean the injectors are dribbling ? Do they now, or did the stock injectors do the same thing ?
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old November 20th, 2020, 12:20
The stock injectors had a dribbling issues i replaced them with a set of 4 hole injectors. Now the fire when the key is in the on position. Pcm is only about 2 years old and all the grounds were supposed to have been replaced about a year ago.
no spark, injectors firing:cps good. Rainman OEM Tech Discussion 11 January 24th, 2015 14:41
injectors not firing munyonb10 OEM Tech Discussion 4 January 16th, 2014 07:29
No start RENIX, injectors not firing. WrenchMonkey OEM Tech Discussion 28 September 13th, 2012 22:02
check to see if the injectors are firing gird123 Modified Tech Discussion 7 November 1st, 2011 15:54
Another no start -- injectors not firing. american_zero OEM Tech Discussion 8 July 8th, 2009 13:44
