Old November 17th, 2020, 15:54
FernGreen's Avatar
FernGreen FernGreen is offline
"Wind Noises" Going Down the Highway
Hey guys I've got a weird one for you. I've got a few 97+ Cherokees so I know what normal XJ wind noise is like when going down the highway but one of my XJ's seems to be significantly louder going down the highway than the rest of my Cherokees. I've notice the noise changes based on speed. It only happens at highway speeds and doesn't seem to matter if its winter/summer or windy/calm day. The "wind noises" start at around 70mph and continue as long as I'm above 70mph. The reason i call it "wind noise" is that's exactly what it sounds like; it sounds like air beating on the front of the jeep. The noise is not consistent it kind of comes in waves.
The noise dies down when I let off (decelerate) and gets bad again when I'm on the throttle again, this all happens when I'm anything above 70mph. This "wind noise" is coming from the front of the jeep.
The jeep is a 2000 lifted 4.5" with 32s (265/70/17 Nitto Ridge Grapplers), A.A. SYE w/ adams rear driveshaft & stock front drivshaft. I still have the stock bumper and end caps which I know are pretty restrictive to air.
One other Cherokee i have that has a 3" lift w/ 31s & the stock bumper is not anywhere as irritable as this one. Has anyone else experienced a noise like this? Everything in the front end has checked out fine, it really does feel like a heck of a lot of air resistance LOL.
I also have another 2000 lifted 4.5" on 32s (32x11.50x15 BFG KO) with an aftermarket front bumper that doesn't hang down as low with no harsh wind noises either.
Old November 17th, 2020, 16:51
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: "Wind Noises" Going Down the Highway
Actual wind noises, or driveline vibrations ?
Check for loose parts or trim, loose radiator shroud, poor workmanship from windshield replacement, doors out of adjustment, failed door seals, missing fender well seals, loose exhaust parts.
Check for tire defects, out of round tires, tread belt separation, tire tread harmonics, failing u-joints, failing unit-hubs, damaged or worn driveshafts, failing pinion or differential bearings.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old November 17th, 2020, 17:12
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Would you happen to have cowl air intake? Spectre, etc. Definite howl under load.
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old November 17th, 2020, 17:37
FernGreen's Avatar
I just have the stock air intake box
Old November 17th, 2020, 21:05
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Originally Posted by FernGreen View Post
The noise dies down when I let off (decelerate) and gets bad again when I'm on the throttle again, this all happens when I'm anything above 70mph. This "wind noise" is coming from the front of the jeep.....
This sounds like the fan clutch is locking up unintentionally instead
of freewheeling. I'd examine it very closely, and look for fluid leaks.
The front edge of the front doors can cause lots of noise, if they're
sticking out from the fender even slightly. Check these with a
straightedge.
Old November 18th, 2020, 06:27
FernGreen's Avatar
straightedge.
It very well could be the clutch! Itís original to the Jeep and doesnít kick on very much at all unlike my others. I do have a small coolant leak. The brand new water pump is leaking just ever so slightly out of the weep hole. The driver side side isnít quite uniform with the bodyline. And something else I didnít think of till you mentioned that is, the hood sticks up a little over the header panel.
Old November 19th, 2020, 05:49
TEX-J99 TEX-J99 is offline
You might also want to have the wheel hubs checked. When those go bad you will definitely hear increased noise that sounds like loud tires or very strong winds.
It's usually noticed before getting to 70 mph though.
Sent from my SM-G950U1 using Tapatalk
32" Tires on 3" of Lift - City/Highway use only PwdrJunki Modified Tech Discussion 32 August 11th, 2011 12:30
WTB fnt pass wind switch, 02 front drv Liiby wind reg jtdesigns SEC For Sale / Wanted Forum 0 May 14th, 2009 08:21
"Not for Highway Use" - Goodyear MT/R??? ocean_jet Modified Tech Discussion 17 July 17th, 2008 23:22
FS: 15"x8" Jeep Ravine Wheels & 30"x9.5"x15" Wrangler GS-A's arfinsd SoCal For Sale 0 February 16th, 2008 22:54
