Old November 18th, 2020, 23:16
bajabronco bajabronco is offline
Re: Started my 4.7 Stroker build today.
Originally Posted by SlowXj View Post
Sorry for the dumb question... If it's to remedial just ignore it please.
What is the reason for the aluminum head? Cooler intake valve temps or something? Does it show higher compression without pinging?
Tya
Aluminum conducts heat faster than cast iron. This helps cool the engine and allows a higher compression ratio with less risk of preignition or detonation, it also weighs about 30lbs less than the iron one. The Edelbrock aluminum head specifically also has a re-designed "modern" combustion chamber, which according to them is more efficient.
Old November 20th, 2020, 00:28
A little bit of progress today. I hadn't gotten a crank girdle, so I had to go grab one as well as washers and bolts. To space the girdle out enough so it doesn't hit the rods I grabbed 14 -3/8' - thick grade 8 washers (.120 washers). I first tried the thinner .060 ones but they were too close.
Installed the girdle with thick 3/8 grade 8 washers and 3/8 nuts.
I also installed ARP studs and nuts and my Harland Sharp roller rockers. I used ARP-200-2403 for the studs but the nuts they come with are too big for the roller rockers. You need 12- 12 point 5/16 nuts as well. I used ARP -67851B
I don't have a woodruff key that fits my crank and harmonic balancer, so I am on pause till I get one that works.
Old November 20th, 2020, 06:16
RCP Phx RCP Phx is offline
You better get some studs for the valve cover too. The rest is coming along and looking good.
Old November 20th, 2020, 06:47
BTW, what are you doing for a valve cover? I modified a stocker at first and then bought the Crown aluminum one. The Crown is nice when I got done fitting all the holes as every one was about a 1/8" off!
Old November 20th, 2020, 07:05
Did you check your lifter pre-load? I originally had to shim my HS rockers, later I purchased some new 3/8" chromoly pushrods in the correct length. The new pushrods also got rid of a little clatter in the valve train.
Old November 20th, 2020, 14:46
I bought some studs for the valve cover, nothing too fancy - just two of these off of Amazon https://www.amazon.com/gp/product/B000CON39Y/ I haven't set the pre-load yet. I just wanted to get the rockers on, and am planning to check everything later.
Old November 26th, 2020, 15:05
bwinter1946 bwinter1946 is offline
As I also live in California I am curious if this engine when complete will pass an emissions test or is this "off road only".
Old November 27th, 2020, 00:04
It will pass emissions. They pass the smog test, and visually it looks exactly the same as the 4.0.
Old November 27th, 2020, 10:29
Thank you!
Old November 30th, 2020, 09:59
twinhauler's Avatar
twinhauler twinhauler is offline
What cam specs you running?
Old November 30th, 2020, 16:26
I am running the Lunati 10680701 - Advertised Duration (Int/Exh): 256/262; Duration @ .050 (Int/Exh): 213/220; Gross Valve Lift (Int/Exh): .484/.507; LSA/ICL: 112/108; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1300-5400;
Started my build today. Palmentech766 Midwest Chapter 5 January 20th, 2015 17:00
Look what I started today Jump This SoCal Chapter 341 November 12th, 2011 15:09
STROKER STARTED!!! Header gets red hot? NHxj4x4 Modified Tech Discussion 9 July 18th, 2005 19:37
Got my stroker started today... tetsulo Jeep Street and Performance 3 July 17th, 2005 16:32
started phase one today!!! SoNjJeep Modified Tech Discussion 5 June 28th, 2004 09:40
