Old November 17th, 2020, 10:44
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: Started my 4.7 Stroker build today.
Originally Posted by bajabronco View Post
It should be at 10.5 to 1 -
Why did you decide to go with this high of a comp ratio, for your elevation isnt that fairly high that close to sea level?
Old November 17th, 2020, 11:41
bajabronco bajabronco is offline
A little more progress on the stroker build. - I finally got the freeze plugs, cam in and timing set on yesterday.
The Melling freeze plugs that I bought were a pain in the ass to try to get in. I was lucky enough to have a local machine shop close by and got another set that actually fit!
We then installed the cam and timing chain. I went with a Lunati Vodoo cam. We degreed the cam and got everything dialed in.
Since I have a 2000 block I purchased a earlier block version spring bolt, I realized I have the bolt but didn't have the cam washer... doh.. That is the next thing I need to find so I can move forward with the build.
Old November 17th, 2020, 12:13
Anak's Avatar
Anak Anak is offline
Stranger
Any details you can share about the Melling freeze plugs to help the rest of us avoid that problem in the future?
Old November 17th, 2020, 13:01
RCP Phx RCP Phx is offline
Ask Russ, I sent him a few that I had sourced that fit perfectly.
Old November 18th, 2020, 00:58
Progress continues on the build. I got some more done after work today - oil pan temporarily installed, lifters in and the head installed
Old November 18th, 2020, 06:12
I see you used ARP head bolts, why didn't you do that for the mains? Since it's a aluminum head you better stud those rocker bosses.
Old November 18th, 2020, 09:50
WAZZUXJ's Avatar
WAZZUXJ WAZZUXJ is offline
SoCal_XJ FB
Uh, it's an aftermarket Edelbrock aluminum head that was designed with larger reinforced rocker bosses from the start.
I am really interested to see how the build turns out as this is exactly how I was planning to build my stroker.
Old November 18th, 2020, 09:58
It's about "turning" a steel bolt while pulling torque on aluminum threads. That's a "no-no", with a steel stud that is loctited in your not applying that force!
Old November 18th, 2020, 10:48
. When it comes to the mains, I just used what Russ provided me for them. When it comes to the heads, I am using ARP studs for the rockers, ARP-200-2403. with my HS rockers. I am not sure what you mean about the rocker bosses.
Old November 18th, 2020, 10:53
It was in response to Wazzu's comment that Edelbrock re-inforces their rocker boss'es but that wasn't the point, glad you decided on the studs. I would do the valve cover also and for the same reason!
Old November 18th, 2020, 13:00
WAZZUXJ's Avatar
SoCal_XJ FB
I know what your point was. My point is that if you don't think Edelbrock engineers thought of this, or you have first hand experience/knowledge of their heads failing by pulling out rocker boss threads, then you should be calling Edelbrock and sharing that information.
Old November 18th, 2020, 13:40
They already know!
Old November 18th, 2020, 13:49
75SV1 75SV1 is offline
About the mains. I do have ARP for the head and I do have them for the mains. I did reuse the stock ones. I am wondering what the difference is between stock with the cradle and the ARPs without the cradle.
Old November 18th, 2020, 19:36
Evan03 Evan03 is offline
Wait wait stop now. Do not put that head on. Your valve cover bolt threads will pull out. Then itl cause a leak down the side of the head. The temperature variation across the leak will be enough to warp the head causing a blown head gasket.
🤫🤑🤔🤫🤫🤫🤔🤐 kidding
Old November 18th, 2020, 19:51
SlowXj SlowXj is offline
Sorry for the dumb question... If it's to remedial just ignore it please.
What is the reason for the aluminum head? Cooler intake valve temps or something? Does it show higher compression without pinging?
Tya
Started my build today. Palmentech766 Midwest Chapter 5 January 20th, 2015 17:00
Look what I started today Jump This SoCal Chapter 341 November 12th, 2011 15:09
STROKER STARTED!!! Header gets red hot? NHxj4x4 Modified Tech Discussion 9 July 18th, 2005 19:37
Got my stroker started today... tetsulo Jeep Street and Performance 3 July 17th, 2005 16:32
started phase one today!!! SoNjJeep Modified Tech Discussion 5 June 28th, 2004 09:40
