Old November 15th, 2020, 23:18
bajabronco bajabronco is offline
Started my 4.7 Stroker build today.
I just started my 4.7L stroker build today for my 2000XJ. The build is composed of a bunch of parts, the main ones and machined block that I got from Russ Pottinger, including a Scat stroker crank, a ported Edelbrock aluminum head, custom pistons made for Russ Pottinger that match the Edelbrock combustion chamber, ported intake, connecting rods, HS Roller Rockers etc. Special thanks to Cal and Mark who are helping with this build. This is my first engine build, and it is great to have fellow members that I can learn from!
Laying out the rods and pistons - and putting them together
Getting the rings installed -and checking the piston position with the combustion chamber of the head
Cal showing me how to install the piston correctly and then test the clearance of the rod bearings
Installing the pistons - you can see how the kidney shape of the piston is directional based on the combustion chamber shape for each piston position.
Pistons and rods are all assembled in the block - that was it for the day, I made some good progress for it being my first time doing any of it!
Old November 15th, 2020, 23:48
Evan03 Evan03 is offline
Very awesome, keep the updates coming
Old November 16th, 2020, 05:19
RCP Phx RCP Phx is offline
Re: Started my 4.7 Stroker build today.
What CR did Russ set it up for?
Old November 16th, 2020, 07:47
Anak's Avatar
Anak Anak is online now
Stranger
Very cool.
I'm jealous.
One of these days...
Old November 16th, 2020, 10:51
It should be at 10.5 to 1 -
Old November 16th, 2020, 12:37
twinhauler's Avatar
twinhauler twinhauler is offline
Awesome. I am picking up all my engine parts next week from Russ. Maybe over Christmas I will have it all built.
Old November 16th, 2020, 12:52
Your going on the high end, what are you doing for tuning?
Old November 16th, 2020, 13:42
75SV1 75SV1 is offline
I thought with an aluminum head, you would go a bit higher on compression?
Old November 16th, 2020, 17:17
No, but it may necessitate running premium. When I did mine I worked with Russ to keep it in the 9.4 range so I would be able to use regular.
Old November 16th, 2020, 19:11
RCPPhx is spot on. I will need to run 91 octane in the engine, but don't want to go any higher than 10.5 to 1. Cal tried running up around 11.5 I believe and had problems with it. If you run higher than 10.5 even with premium you have to pull so much timing out to alleviate pinging that you start reaching a point of diminishing returns.
Ron, I am planning on having Mark and Chris tune it for me here in LA.
Old November 16th, 2020, 20:17
That will get it done, when I did mine Chris was definitely on the list of 3!
Old November 16th, 2020, 20:40
Btw, I hope you are planning on getting rid of the coil rail?
Old November 17th, 2020, 01:02
I got rid of it this summer and did the viper coil swap, so I am all good there!
Old November 17th, 2020, 05:43
I did the same. I did not want the $ for gas. Mine will be a road going, with light trials. I do have a Viper coil planned. I'll be coping your bracket or at least use the idea.
Old November 17th, 2020, 06:32
If you didn't already I would p/u the Screamin Demon coil. I was able to open the gap on my Champion plugs to a safe .047" gap.
Started my build today. Palmentech766 Midwest Chapter 5 January 20th, 2015 17:00
Look what I started today Jump This SoCal Chapter 341 November 12th, 2011 15:09
STROKER STARTED!!! Header gets red hot? NHxj4x4 Modified Tech Discussion 9 July 18th, 2005 19:37
Got my stroker started today... tetsulo Jeep Street and Performance 3 July 17th, 2005 16:32
started phase one today!!! SoNjJeep Modified Tech Discussion 5 June 28th, 2004 09:40
