Old November 14th, 2020, 16:03
Roryd89 Roryd89 is offline
Improving ride on a DPG OME lift
I bought my cherokee with a 2.5 rough country lift on it and the ride was obviously horrible so i finally got around to getting the dpg old man emu 2.5 ultimate kit installed on it. The ride quality is a little improved but not nearly what i was hoping for out of a $1,500 suspension kit. The jeep is my daily and the roads where i live are not great, so I'm hoping for some suggestions on how to get the ride a little smoother.
thanks in advance
Old November 14th, 2020, 18:22
jrmyers's Avatar
jrmyers jrmyers is offline
Re: Improving ride on a DPG OME lift
How many miles are on the new suspension?
Can you explain more how the ride quality is poor?
Let's say you hit a
Old November 14th, 2020, 18:26
jrmyers's Avatar
*Let's say you hit a small bump across the road going about 30. How exactly does the front take the bump? What about the rear? Any steering feedback?
Old November 14th, 2020, 18:52
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is online now
What shocks?
What angle are your rear shackles at?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old November 14th, 2020, 20:25
Anak's Avatar
Anak Anak is offline
Stranger
What size tires (including load range) are you running and what tire pressure?
Old November 14th, 2020, 21:39
Evan03 Evan03 is offline
I checked out the kit. Not realy sure what to think.
Coil springs and leafs.
Whats shackle look like. Is it actually 2.5" lift?
Control arm drop brackets on it? I would
Drop brackets, good shackle angle good shocks. Not sure anything needs to be branded ome.
I have read where people talk good about the ome shocks. But I think they're just a cheap cookie cutter shock. But I think the same of bilstein 5100s
Yes tire psi plays a roll. I run less tha 20psi
Old November 14th, 2020, 22:34
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
So Evan, what's your shock of choice? In case I need to replace the OME I have. (I'm sure that topic is like legs or breasts, Ginger or Maryanne). Not bad but nothing to compare with and nothing special as far as I can tell on my OME setup.
Sounds like the OP is on the same journey as me..lol.
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old November 15th, 2020, 22:28
Money no concern.
Accutune Fox shocks valved to my xj weight set for the trail with 33s with low speed compression adjuster dials so i can firm up or soften to my mood or xj on board weight at any given time.
Cheap shocks
Kyb monomax valved for the front of the dodge pickup installed on the front of the jeep.
Im currently running fox 2.0 of the 2019 gladiator. They work well great on rd and off road ride. But front is pretty soft riding after going long arms. I dont run swaybars.
Good budget shock but they don't bolt on our xj.
Bilstein 5100 with short arms this is slightly softer shock than the kyb. Works well on short arms because more force is transmitted through the arms.
Flatter longer arms will like the firmer valved 5125 shocks because more force is directly sent through the shocks.
Thats my preference and take on shocks.
Old November 15th, 2020, 23:33
NOTNSUV's Avatar
You Guys ROCK!
Money no concern.
I kind of hi-jacked this thread. Hope the OP is finding what he needs.
I just read through the Accutune guide to measuring for shocks.. kind of involved with weights and measures. If I were to go that route could I likely choose the same valving you have, provided our setups are very nearly the same? Yup, yup.. lazy. Those CD Adjustable sound like a sweet setup.
I looked at the FOX reservoir shocks for my F350 but just ended up with the standard 2.0 on stock suspension (hated the FX4 shocks).
I've looked over a video on measuring for shocks but nothing nearly as involved as Accutune recommends.
Thanks!
Old November 15th, 2020, 23:45
Some one put there has a similar build to yours and accutune likely has valved shocks for them.
I've spent some time talking with accutune through phone and email. It would definitely be worth your time. They can explain things much easier over the phone.
I can run most any length shock die being able to tune upper and lower mounting points.
Im not running accutune valve shocks. Mine are just over the shelf standerd valving that fox sends out (cookie cutter)
I've done alot of research also have time talking with foa and the othere big name shock king.
Im convinced accutune valved shocks are probably the best route to take as an investment in the offroad world. The shkcks can be tuned for vehicles later on down the rd or as the current vehicle transforms.
The difference between fox 2.0 and cheaper shocks is pretty noticeable. I can only imagine custom valved would be an incredible eye opener
Old November 16th, 2020, 06:46
75SV1 75SV1 is offline
Trying to think through this and what affected my problems. I am thinking what condition the steering gear box is. What if any improvements to the steering linkage. Ball joints? Bearing hubs? Alignment? Alignment done by someone who knows what they are doing? What size tires, as mentioned before? Steering Stabilizer replaced? With what? Control arms? Stock should be OK on this lift, but condition?
Old November 16th, 2020, 10:53
Sean778's Avatar
Sean778 Sean778 is offline
Did you bleed the air out of the shocks?
https://www.knowyourparts.com/techni...ock-absorbers/
Old November 20th, 2020, 09:09
Let's say you hit a
new suspension has maybe 50 miles on it, i was wondering if it would settle down more after it gets a little broken in.
its just a little jarring is the best way i can describe it i guess, steering is fine but i can feel every bump and feel it rattling the whole jeep. the rear is the worst it feels like its rattling body panels lol
Old November 20th, 2020, 09:11
Originally Posted by IslanderOffRoad View Post
What shocks?
shocks are old man emu nitro charger sports, and the shackle angle is stock still? whatever that is. never did anything with the angle
Old November 20th, 2020, 09:13
they're 29" back country all terrains, was planning on going to 31s next but was just laid off so that may have to wait. not sure on the pressure at the moment, i was recommended to put it at 32psi to improve the ride and still need to do that.
Improving MPG SEXJ96 OEM Tech Discussion 16 August 17th, 2018 21:04
Improving rear suspension ride quality AZ XJ Modified Tech Discussion 22 September 20th, 2009 22:08
air-ride lift?? DeezUU Modified Tech Discussion 12 April 12th, 2007 02:19
Improving MPG RichP Non-Tech / Off Topic 10 October 5th, 2005 21:10
lift ride tony r Modified Tech Discussion 11 April 22nd, 2004 14:44
