Old November 14th, 2020, 07:37
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: What's next for a mild trail rig?
Originally Posted by CRBMAN View Post
Also a SYE. Any suggestions ? the SYE will probably be next.
Advance Adapter SYE works well for me, DO NOT BUY Rugged Ridge, Crown Automotive, or any other unknown / store brands.
Stick with JB or AA.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old November 14th, 2020, 09:39
Evan03 Evan03 is online now
Im on bored with jb conversations. Im looking into the super short version mainly because my tcase may grow
Longer.
https://www.jbconversions.com/index2.php?pc=1
Anak has some great info.
Jb conversions seem to be top knotch.
Im liking northwest fabworks to.
Old November 15th, 2020, 22:35
Jeep, winch welder what else is really needed
To drag things like digging buckets in out of the rain. Straighten bumpers. Pull fence posts out of the ground. Pull trees over.
Can you tell im pushing the winch
Old November 16th, 2020, 15:14
maxbraketorque maxbraketorque is offline
Originally Posted by Evan03 View Post
So rear output goes to rear axle front out put to front axle.
If transmission is lowered 1" at the cross member the entire unit pivots on the motor mounts and lowers. Everything the same. Possible un measurable angle change due to pivoting in motor mounts
Tcase clocking would be the only way to actually change things to front vs rear axle.
This is correct. Dropping the tranny/tcase benefits both front and rear driveline angles. The angle change on the front driveshaft at the tcase due to the entire drivetrain rotating around the engine mounts is small and is more than offset by the tcase being lowered. And besides that, its on the double cardan side of the driveshaft, so its a non-issue anyhow. But the lowered tranny and tcase does affect ground clearance. If ground clearance is not expected to be an issue, I'd leave the tranny/tcase lowered. Then there is no need for an SYE for the rear drive shaft, at least for a 3.5" lift.
As far at the thread topic goes, I'd first change all fluids, thermostat, spark plugs, O2 sensors, and maybe the coil pack. If the valve cover gasket is leaking, I'd change that. I also recommend the pan and rear main seal gaskets. My 200 XJ only had 109K miles on it when I bought it, and its visually in near perfect condition, but when I had the rear main seal changed, we found that the old, hard seal had worn a groove in the sealing surface on the crank. It will forever leak at the rear main seal. I recommend to everyone to proactively change the rear main seal before that happens. Might also be a good idea to do the crank angle sensor as well.
After that, I'd agree that a winch, tow hooks front and rear, and some kind of limited slip or locking rear diff are good steps for off roading. And good tires. Could also consider installing a steering shaft brace.
One question I'm curious to hear from others is whether increasing the final drive ratio is worth the cost when running just 31" tires (which is what my XJ has as well).
Old November 18th, 2020, 04:46
89Mock 89Mock is offline
Originally Posted by Tim_MN View Post
If you lower the t-case rear output, the front output is raised.
For mild to medium trails, and with an adult attitude driver, a winch IMO, is not essential, as long as there is a properly equipped group of 4x4's to assist should there be a mishap, or a stuck. That money could be put to more useful basic upgrades.
Equipment choices are personal, based upon ones needs, and terrain commonly traveled. I have been stuck plenty, but have never had a "Bubba, hold my beer and watch this" episode.
Your definition of mild and someone elseís are different. Iíve used my winch and so have others at points in trail we were greatful to have them. Itís $300 for a harbor freight one and I one of the bet recovery tools. Iíd consider it basic and Iím just starting out off roading.
Old November 18th, 2020, 04:51
Change your crank position sensor and keep the one you have as a spare because you know it works. If the CPS goes out youíre going nowhere until itís fixed.
Rock sliders, bumper with recovery points in the rear, frame stiffeners, etc.
Old November 19th, 2020, 08:53
TEX-J99 TEX-J99 is offline
I have a 1999 XJ with 189,000 miles. I replaced the entire exhaust from the header back this year because of a cracked header. I went with Banks Power for everything, except for the catalytic converter, which is a Flowmaster.
You probably won't have the cracked head issue for awhile, but if you do, you'll notice a sluggish vehicle with not much power.
Replacing the exhaust brought the power of the 4.0 back and it sounds like a deep throated bad ass now. Not loud, but just the perfect deep rich tone.
Winch and bumpers for sure if you want to get into anything challenging and worth a risk.
Old November 19th, 2020, 17:42
old_man's Avatar
old_man old_man is offline
There is no such thing as a mild trail rig, only an unfinished one.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old November 19th, 2020, 18:15
Anak's Avatar
Anak Anak is offline
Stranger
Boy, ain't that the truth.
Hence the nickname my Jeep has earned itself.
Old November 20th, 2020, 04:49
Tim_MN's Avatar
Mine started out mild, a budget boost, and the factory installed Limited Slip. Modifications were made as necessary to meet my specific needs and the trails I run on. 18 years later and I still have no winch.
Old November 20th, 2020, 07:26
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Will it throw a code when the CPS goes south? Or, what are the symptoms.
Good call, I have one on order. Carry a TPS also but I don't think that will shut you down.
I carry an OPDII reader with diagnostic app also. Just for kicks.
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old November 20th, 2020, 07:44
It stops running. I don't think the ECU puts up a code. If you carry a spare sensor, also make sure you have enough socket extensions to install it. It takes something like 2-3 ft of socket extension. Check out some of the videos on youtube.
Old November 20th, 2020, 08:52
NOTNSUV's Avatar
You Guys ROCK!
Yup, watched YouTube on it.
Good source for genuine Mopar.
www.moparpartsgiant.com
Also ordered a serpentine belt and TPS to carry (don't think the TPS will cause it to not run but I've lost them in the past).
Old November 20th, 2020, 11:37
Tim_MN's Avatar
Carry a spare CPS and TPS. If you get the TPS really wet, it will fail.
Old November 21st, 2020, 13:29
Phil's Avatar
Phil Phil is offline
Pro tip: before replacing the CPS, try unplugging and replugging it a few times to clean the contacts in the, uh, plug.
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
My Mild MJ cody4359 Jeep Comanche MJ (1985 - 1992) 122 February 27th, 2019 12:05
my mild mj cody4359 NorthWest Chapter 30 December 11th, 2017 23:50
mild 95 XJ POLAR_JEEP_04 MWC For Sale/Wanted Forum 0 December 1st, 2009 19:32
Short Arm vs Long Arm - DD & Mild Trail Rig 97stomper Modified Tech Discussion 36 October 16th, 2009 10:46
Looking for a DD/mild trail XJ jms OEM Tech Discussion 2 May 13th, 2004 15:10
