Old November 12th, 2020, 20:41
CRBMAN CRBMAN is offline
Question What's next for a mild trail rig?
I recently acquired a 2000 xj with 66k miles. It came with a RE 3.5 lift, a 1" TC drop and 31's. It does not have a SYE . The things needing attention are the motor mounts ,bump stops and some surface rust in spotty places underneath. It has stock front and rear bumpers and stock steering components. It drives very well with no apparent vibrations at any speed. The engine is also completely stock. I guess my question is where would you spend your money next other than the items needing immediate attention? Oh, and the interior is mint with a new stereo and speakers. This thing will only see mild to medium trails. Thoughts?
Old November 12th, 2020, 21:02
Anak's Avatar
Anak Anak is offline
Stranger
Re: What's next for a mild trail rig?
66K miles? Nice find.
My biggest concern would be the 0331 head. If you are not aware of the issues surrounding this head then do a search. It is prone to cracking. A TUPY head is generally the fix. Some folks get lucky and have no issues with the 0331 head, but it is a known problem.
If motor mounts are bad don't be surprised if it turns out you also have a cracked exhaust manifold. Be on the lookout for that.
As to what to modify next, I would say drive it until it shows you what you need to do next. Save your money until you know you need to do something, and then you will know you are making the right decision.
Old November 12th, 2020, 21:06
Evan03 Evan03 is offline
Winch and recovery .
Then rear locker
Old November 13th, 2020, 04:54
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
1) SYE. The Transfer Case drop is hard on the motor mounts and if you still have the low pinion D30 front axle the t-case drop increases the front pinion/drive line angles.
2) Skid plates.
3) Recovery points front and rear, and recovery gear, ( winches are highly optional if you adventure off-road with others ).
4) Rear locker if you have a Chry 8.25, 8.25 axle swap if you have a D35.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old November 13th, 2020, 06:47
75SV1 75SV1 is offline
Steering box brace and possibly a trackbar brace. Brake upgrade, I'd start with pads. Black Magic. I'd keep an eye on the head and coolant. Then change if necessary. I'd probably change the harmonic balancer. Or at least check the rubber elastomer for cracks. Paint a white stripe between the hub and outer ring. Check it periodically.
Old November 13th, 2020, 07:18
Tell me why it would make it worse on the low pinion front axle to lessen driveline angle by barely lowering transmission.
I used to think a winch was un needed since getting one ive since decided that its an essential tool i won't be without. Been thinking about doing a winch on my pickup to front bumper and a head ache rack rear winch
Old November 13th, 2020, 07:32
Tim_MN's Avatar
If you lower the t-case rear output, the front output is raised.
For mild to medium trails, and with an adult attitude driver, a winch IMO, is not essential, as long as there is a properly equipped group of 4x4's to assist should there be a mishap, or a stuck. That money could be put to more useful basic upgrades.
Equipment choices are personal, based upon ones needs, and terrain commonly traveled. I have been stuck plenty, but have never had a "Bubba, hold my beer and watch this" episode.
Old November 13th, 2020, 07:43
RCP Phx RCP Phx is offline
It raises the front output shaft in "degree's" and since the LP D30 axle is already set 2* lower than a HP D30 it just makes things worse faster.
Old November 13th, 2020, 07:45
srb531 srb531 is offline
zj tie rod
Old November 13th, 2020, 08:55
So rear output goes to rear axle front out put to front axle.
If transmission is lowered 1" at the cross member the entire unit pivots on the motor mounts and lowers. Everything the same. Possible un measurable angle change due to pivoting in motor mounts
Tcase clocking would be the only way to actually change things to front vs rear axle.
Most xj on forums or driving around built however handy don't go off road so in that case a winch is not needed or a locker or lift or anything.
In that case only survival gear is needed for break downs or survival through plague in shit.
Old November 13th, 2020, 10:09
Phil's Avatar
Phil Phil is offline
Seat time, a wheeling buddy, and gasoline.
Maybe front tow hooks, rock sliders, a rear hitch before the more medium trails.
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old November 13th, 2020, 10:46
hjeepxj's Avatar
hjeepxj hjeepxj is offline
#OCDINK
Originally Posted by Tim_MN View Post
1) SYE. The Transfer Case drop is hard on the motor mounts and if you still have the low pinion D30 front axle the t-case drop increases the front pinion angle.
2) Skid plates.
What Tim here said.
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction*
Old November 13th, 2020, 11:56
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
This. Absolutely this.
What Phil listed is all you need right now - Add the recovery points (and maybe sliders and a gas tank skid), get out on the trails, and learn what it can do with what it already has. I guarantee you'll be amazed at what it can conquer.
Driving experience and a good knowledge of your rig (how it handles, the sounds it makes as you flex the suspension, how each of the bits underneath sound/feel when you bang them into rocks ) will take you a LONG way on the trails. Once you've gotten a good feel for how it works now and how you drive, you'll be in a better position to judge which mods are the best ones for YOU to do next.
Jeep mods are like tools - you don't always need the biggest ones. Even when you do, you can often get more of out of the big ones if you've learned to wield the smaller ones to maximum effect first...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old November 13th, 2020, 15:38
Thanks guys. Thinking about new bumpers. Also a SYE. Any suggestions ? the SYE will probably be next.
Old November 13th, 2020, 19:28
Anak's Avatar
Stranger
If you are asking which SYE, JB Conversions gets my vote.
Here is my perspective on them: https://www.naxja.org/forum/showthread.php?t=1144685
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
maxbraketorque
My Mild MJ cody4359 Jeep Comanche MJ (1985 - 1992) 122 February 27th, 2019 12:05
my mild mj cody4359 NorthWest Chapter 30 December 11th, 2017 23:50
mild 95 XJ POLAR_JEEP_04 MWC For Sale/Wanted Forum 0 December 1st, 2009 19:32
Short Arm vs Long Arm - DD & Mild Trail Rig 97stomper Modified Tech Discussion 36 October 16th, 2009 10:46
Looking for a DD/mild trail XJ jms OEM Tech Discussion 2 May 13th, 2004 15:10
