Old November 12th, 2020, 12:01
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Re: Long Arm 'Upgrade'
Originally Posted by Evan03 View Post
My arms provided a night and day improvement in rude quality on rd and washboard rough stuff.
Sfr arms will look very similar just alittle more angle .
Stuff that used to make me cringe with short arms. Is now fun to hit at speed.
Maybe I'm getting carried away and over-thinking (as usual).
I've already installed drop shackles in the rear and have SRB in hand to get a better shackle angle. This combo will net some lift in the rear and might be a stink-bug look.
Hence the curiosity about what to do up front to level and gain some articulation as well.
Current angle on the JKS adjustable upper control arm is 16* FWIW. I'm still not clear on why these won't work with drop brackets (per Rocky Road, any but stock are too long). I don't know how short the JKS will adjust.
If I go full-tilt-boogie these are my thoughts, for now.
SFR 4-link
https://www.stinkyfab.com/collection...31871076860040
Metalcloak progressive coils, if I need to raise the front. They have them in 3.5", 4.5" and 6" (TJ interchange on the 4.5/6")
https://metalcloak.com/tj-lj-xj-wran...3-5-front.html
Shocks to be determined. Fox? I've had good luck with them.
So Evan, where in Idaho? Some good wheelin' around Jarbidge and NE NV.
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old November 12th, 2020, 12:12
NOTNSUV's Avatar
You Guys ROCK!
From StinkyFab:
"If you're trying to decide between either the 3 or 4 link, here's the difference. In THEORY a 3 link will articulate more. It has zero inherent bind and therefore can move more freely. In reality however the limiting factors on any full bodied vehicle are the length of the shocks, size of tires and body clearance.
The 4 link does have some bind in it which is why you don't want to use solid joints like heims, however in basically all situations it is more stable, more predictable and puts power to the ground better. Again, articulation will mainly be limited by the shocks and body, so articulation between the 2 is really going to be the same. The 4 link just performs better all the way around."
Old November 12th, 2020, 13:05
Evan03 Evan03 is offline
Long Arm 'Upgrade'
If your uppers and lowers are adjustable id throw drop brackets on and run it.
That way youl be able to adjust castor.
Before you put on drop brackets set angle finder on upper ball joint to get a base line#. Reinstall and set arms to match that or slightly more positive if it didn't drive super straight Before doing drop brackets
Theres quite a few trails around idaho
Old November 12th, 2020, 13:08
Long Arm 'Upgrade'
Boise area. Yes jarbidge is neat ive never ran trails there but have loved in a camper working there
Sawtooths, owhees, sand rocks kinda have a mixed bag of terrain here
Old November 12th, 2020, 15:22
NOTNSUV's Avatar
You Guys ROCK!
With Rocky Road telling me their drop brackets are meant for stock/OEM length control arms I emailed JKS since that's the adj. CA I have.
Reply: "With the JKS arms as short as you can make them, they will be at stock length".
So of course, I'm contacting RR again to see what they say.
$100 more for RR over RE it appears but the RR include the rear 'brace'. Still looking for others if you care to recommend.
Old November 12th, 2020, 18:28
NOTNSUV's Avatar
You Guys ROCK!
Mixed signals from RR. On the phone was told the above.
Latest email:
"Actually, our CAD kits can work with stock or aftermarket control arms.
Most control arms are designed for a fixed length for 3-4" of lift, if the Jeep has more lift, then even with fixed control arms, our CAD kits work excellent.
That said, adjustable control arms are ideal since you can fine-tune the length of the control arm to compensate for their drop. So it is no problem at all to use our CAD kit with adjustable control arms.
This will work for your setup!"
Their brackets are $240
Old November 12th, 2020, 19:44
just or any drop brackets. Your jeep will ride and handle much better
Old November 12th, 2020, 20:09
gearwhine gearwhine is offline
rockyroads web page reads, and looks, like a spam email selling enlargement pills.
Sensationalist claims, bad mouthing other options, and random opinions shown as facts that are there to make you say "yeah, I need that!"
I would never give them a dime. I'd much sooner give it to rough country for drop brackets. I had Rubicon Express's a long time ago... they were great.
Old November 12th, 2020, 20:19
RCP Phx RCP Phx is offline
That's the Rocky Road I've always known, started with a bad deal 15yrs ago!
NOTNSUV's Avatar
You Guys ROCK!
Agreed. I'm looking at other brands and trying to find some with support bracket included or at least available option.
Old November 12th, 2020, 21:06
SlowXj SlowXj is offline
Long Arm 'Upgrade'
Rubicon express and rough country both make them. Much better choice than rr....
Old November 12th, 2020, 21:11
NOTNSUV's Avatar
You Guys ROCK!
Looks like Rough Country does have the rear support.
All say 4.5" minimum lift. Looks like new springs might be in order also since my OME is 3.5"
Thanks.
Old November 12th, 2020, 22:35
Let's say 3.5" myswell be 4" and damn near 4.5.
Bolt them on whatever lift height your at. The lower the better 3" is perfect get some good flatter arms and much nicer ride then drop brackets on 4-6 lifts.
Old November 13th, 2020, 10:07
Phil's Avatar
Phil Phil is offline
The RE brackets drop about 3”, so at a 3” lift they’ll get you about stock angles. The braces are not included, but are available.
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old November 13th, 2020, 13:02
NOTNSUV's Avatar
You Guys ROCK!
Available from where? Looked for 2 days.
Ordered from Rough Country instead.
RC long arm upgrade help please. rickypistols Modified Tech Discussion 4 October 13th, 2017 21:12
iron rock long front long arm upgrade: ZJ grandrunner SoCal For Sale 9 April 24th, 2010 22:30
RE Long arm upgrade 440swepty SEC For Sale / Wanted Forum 2 March 7th, 2009 19:46
long arm upgrade? jeepnleo Modified Tech Discussion 7 August 28th, 2008 11:35
Long arm upgrade Red98 Modified Tech Discussion 1 August 24th, 2006 17:42
