Old November 18th, 2020, 19:57
maxbraketorque maxbraketorque is online now
Ring & pinion ratio vs tire size
All the ring and pinion ratio vs tire size charts for the XJ simply adjust the R&P ratio to offset the increased tire size on a 1:1 ratio. So if I were running a 31" tire which is about 10% large diameter than stock by the numbers on the tires, then I would change from a 3.55:1 to a 3.90:1 R&P. And for 33" tires, it would be 4.10:1. However, I've now seen plenty of posts where people with 33" tires are running 4.56 and 4.88:1 R&P ratios. Since the TC has a 4LO option, I don't understand the point of substantially undergearing. Does rock crawling or navigating over very difficult terrain benefit from doing this even with an auto trans?
Old November 18th, 2020, 20:22
EricsXJ's Avatar
EricsXJ EricsXJ is offline
NAXJA Member #616
Re: Ring & pinion ratio vs tire size
Originally Posted by maxbraketorque View Post
All the ring and pinion ratio vs tire size charts for the XJ simply adjust the R&P ratio to offset the increased tire size on a 1:1 ratio. ...
I don't know what charts you are looking at but this is wrong and not based on reality. Yes for 33's the ideal gears for most people is 4.56. My ideas as to why a straight 1:1 adjustment does not work is because in real life you are not just increasing tire diameter. There are other factors that come into play such as weight. Bigger tires are heavier... along with other additions commonly made at the same time as the bigger tires such as aftermarket bumpers, sliders, skids, cages, spares, tools, and gear. There is also a vertical change both due to taller tires but also with an accompanied lift. This probably has more effect at highway speeds with wind drag rather than slow crawling, but it is a factor.
www.ericsxj.com
Old November 19th, 2020, 08:19
ok. I wouldn't have thought people running 33's and higher would care much about driving faster than 60 mph where wind speed matters more, but additional vehicle weight and increased inertial mass of the wheels does make sense for raising up the cruise RPM to higher power portion of the powerband.
I'm on 31's now with stock 3.55 R&P, but I'm considering swapping up to a higher numeric R&P ratio. Trying to figure out what makes sense. At some point in the future I may want to go to 33" tires, and I don't want to do another R&P swap at that time.
Old November 19th, 2020, 08:35
RCP Phx RCP Phx is offline
To answer the other half of your question, the stock 231 and 242 TC's only have a 2.72 reduction in low range and isn't considered much. I have had a 4.1 in my NP231 for twenty years and a NV OR241 and will never go back to stock. Compare your final drive ratio's and you'll see there is a major difference.
Old November 19th, 2020, 10:05
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
There's gotta be a thread on xfer case gear reduction? Brand names, etc.
Found this with little effort however.
http://www.4x4wire.com/jeep/tech/xfer/tera4_1/
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old November 19th, 2020, 10:08
Thanks. My guess would be that low of a gearing is mostly needed for very extreme terrain. I'm more in the range of basic double-track. I'll likely go with 4.10 R&P.
Old November 19th, 2020, 10:18
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
My XJ is on 33's and 4.56's with a 5 speed. I do care about driving faster than 60mph as I drive it to places to wheel. Averaged around 70mph driving from Houston to Moab a few weeks back.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old November 19th, 2020, 12:26
gearwhine gearwhine is offline
I'm waiting on some new 4.56 gears right now. 3.55s on 31s with an AW4 currently, and it is pretty horrendous. It bogs big time. I can't wait to get the new gears in.
I have driven 3.07s on 33s with a manual for a while before going to 4.56. That set up more doable than the auto as there is more control, but it still sucked.
4.56 was still extremely solid highway speeds on 33s. I, personally, would never go to a lower numerical gear than 4.56 on 33s even if it's a highway only XJ. Which is why I'm choosing 4.56 for 31s this time around.
Old November 19th, 2020, 12:55
WAZZUXJ's Avatar
WAZZUXJ WAZZUXJ is offline
SoCal_XJ FB
Typical gear calculation: New tire size / stock tire size x current gear ratio = New gear ratio (ex: 33" tire / 28" stock tire x 3.54 stock gear = 4.17 (4.10 ratio).
Just calculating percentage change in tire size diameter is why most gear charts are incorrect though and end up leaving you under geared (under powered).
Tire diameter increase does not account for the tire weight increase which is considerable when it is added as rotational mass. Cruising rpm's will increase due to this added weight as the engine will have to use more power to move them. Then consider most off-road vehicles include added weight in the form of bumpers, rock sliders, roof racks, frame stiffeners, tube flares, recover gear, etc, etc.
A better calculation:
33" tire / 28" tire x 2000 stock cruising rpm = new goal rpm. (33/28*2,000= 2,357). Using that calculation a 4.56 gear ratio will put your rpms at 2,263 at 65mph. 4.88 at 2,422 rpm's at 65mph. You can see why these are the more regularly run and recommended gear ratios.
Old November 19th, 2020, 13:49
Thanks much. Sounds like if I'm going to stick with 31" tires for sure, 4.10 is a good choice, but if I feel pretty certain that 33" tires are in my future, I should go with 4.56.
Old November 19th, 2020, 14:03
75SV1 75SV1 is offline
http://www.grimmjeeper.com/gears.html
That one gets post in most of these types of discussions. I'm on 4.10 GR and an Auto. I did have 31's. It was a good ratio. I'm on 32's not. A bit doggy. It could be other issues. Also, depends on what you want out of your ride. Do have a build going on with 3.73 auto and 30.5's (metric). Seems good, but haven't run it on the highways. I have a 231, but plan a 241TC. I could see say a 3.73 and a 4:1 TC in this setup. Hiway milage, then lower TC for offroad.
Old November 22nd, 2020, 14:25
EricsXJ's Avatar
NAXJA Member #616
Yes.
www.ericsxj.com
Old November 22nd, 2020, 21:36
Ring&pinion ratio IsraeliXJ OEM Tech Discussion 5 November 10th, 2010 05:30
3.73 ratio Dana 30 Ring and Pinion OkieXJ Red River Chapter For Sale/Wanted 0 May 6th, 2010 15:20
NIB 8.25" ring and pinion, 3.55 ratio GrimmJeeper SoCal For Sale 4 May 27th, 2008 21:12
FS: Dana 44 Ring and Pinion Gears - 3.73:1 ratio Root Moose For Sale: Private Party Only. XJ ITEMS ONLY 0 November 22nd, 2004 17:37
Chrysler 8.25 4.10 Ratio Ring & Pinion for Sale Planetcat For Sale: Private Party Only. XJ ITEMS ONLY 0 December 12th, 2003 17:04
