Old November 19th, 2020, 08:28
TEX-J99 TEX-J99 is offline
Track Bar and Frame Side Mount
I recently installed a Steinjager track bar that has a ladder bar adjuster, which I unfortunately didn't learn could be adjusted while still on the vehicle, until taking it off the vehicle (oops). I needed to make it longer to center up my axle with the frame.
I tried loosening the two jam nuts when I had it removed from the XJ and I got nowhere. I used a wrench and a heavy duty hammer. Nothing budged.
So, I went to put it back on the vehicle after learning about the ladder bar adjustment function.
Foiled again. I can't mount it back on. Now the mounting hole of the frame side bracket won't center with the hole of the track bar. The track bar is making contact with the interior wall of the bracket before the two reach alignment.
I've tried aligning both to top and bottom sides first and got no good results either way.
Could I some how have bent or distorted the mounting bracket?
Sent from my SM-G950U1 using Tapatalk
Old November 19th, 2020, 08:43
RCP Phx RCP Phx is offline
Re: Track Bar and Frame Side Mount
That's only the second time in twenty years I've even seen that brand. It definitely is not one of the preferred trackbars! It looks like it should mount on the bottom of a stock trackbar bracket.
Old November 19th, 2020, 09:42
I think you're right. I think you're exactly right. The heim joint should be below the bracket and only the nut should be in the bracket cavity. Thanks for knocking me upside the head here. I really appreciate it!
Track bar frame mount Hurricane06 Modified Tech Discussion 13 June 8th, 2019 13:42
WTB: Stock frame side track bar mount karstic SoCal For Sale 10 October 17th, 2014 21:27
Wanted: factory Frame side track bar mount. SPXJ SoCal For Sale 9 November 4th, 2013 21:46
WTB: stock or double shear track bar mount (frame side) jumpnjeep SoCal For Sale 8 October 6th, 2012 20:58
Best track bar frame mount? Goatman Modified Tech Discussion 41 August 28th, 2003 19:55
